メインコンテンツにスキップ
Breville JE98XL Juice Fountain Plus Filter Basket Replacement
必要な工具と部品
  1. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Pulp Basket: 手順 1、 1の画像 1
    • Place the juicer on a flat surface. Make sure the juicer is unplugged and in the "off" position. For the following steps, the pulp basket is on the left.
  2. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 2、 1の画像 1
    • Tilt the juicer slightly to the right so the pulp basket is off of your surface.
  3. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 3、 1の画像 1
    • Pull the pulp basket down and out from under the juicer cover.
  4. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Lid: 手順 4、 2の画像 1 Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Lid: 手順 4、 2の画像 2
    • Place one hand on either side of the safety locking arm.
    • Disengage the locking mechanism by pulling down on the lever with even pressure. The lever should be free to move up or down once it has been properly disengaged.
  5. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 5、 2の画像 1 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 5、 2の画像 2
    • Firmly grip both sides of the juicer. Twist clock-wise and lift to remove the lid.
  6. Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Filter Basket: 手順 6、 2の画像 1 Breville JE98XL Juice Fountain Plus Filter Basket Replacement, Filter Basket: 手順 6、 2の画像 2
    • Twist the filter bowl that surrounds the basket in a counterclockwise fashion. Lift the bowl straight up to remove it from the juicer.
  7. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 7、 3の画像 1 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 7、 3の画像 2 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 7、 3の画像 3
    • To remove the filter basket from the surrounding bowl, use a plastic opening tool to create separation between the basket and the bowl.
    • Once there is enough room, place your fingers under the grooves of the filter basket and lift up.
  8. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 8、 2の画像 1 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 8、 2の画像 2
    • In order to access the cutting disc, the basket must be removed from the base. To do this, simply lift the basket up and off of the base.
  9. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 9、 2の画像 1 Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 9、 2の画像 2
    • To remove the cutting disc, unscrew the three Phillips #1 screws.
  10. Breville JE98XL Juice Fountain Plus Filter Basket Replacement: 手順 10、 1の画像 1
    • With all three screws removed, use a plastic opening tool to lift the cutting disc out of the filter basket.
    • The cutting disc has many small and sharp blades. Make sure to hold the disc in between blades when handling.
終わりに
作成者
2人の作成者と共同で作成されました。
Madison Burgess
メンバー登録日: 10/06/16
499 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 15-1, Livingston Fall 2016 Cal Poly, Team 15-1, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S15G1
3 メンバー
4のガイドは作成済み
2 件のコメント
What are the 3 exact screws for this part? Lost one of the screws when taking apart.
Adam Samsonov - 返信
I Twist the filter bowl that surrounds the basket in a counterclockwise fashion. And try Lifting the bowl straight up to remove it from the juicer, but it will not seperate any suggestions?
Robert morris - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 24
今までの合計 1,650
