メインコンテンツにスキップ
Breville BKC600XL On/Off Switch Replacement
必要な工具と部品
  1. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 手順 1、 3の画像 1 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 手順 1、 3の画像 2 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #1: 手順 1、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: 手順 2、 2の画像 1 Breville BKC600XL On/Off Switch Replacement, Black Water Inlet: 手順 2、 2の画像 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: 手順 3、 2の画像 1 Breville BKC600XL On/Off Switch Replacement, Bottom Cover #2: 手順 3、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL On/Off Switch Replacement, Power Cord: 手順 4、 2の画像 1 Breville BKC600XL On/Off Switch Replacement, Power Cord: 手順 4、 2の画像 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL On/Off Switch Replacement, On/Off Switch: 手順 5、 1の画像 1
    • Carefully pull both the red and blue wires that covered at the tip.
    • Do not yank them out from the other end. Move them aside and out of the way.
  6. Breville BKC600XL On/Off Switch Replacement: 手順 6、 1の画像 1
    • Carefully remove the On/Off Switch from its slot on the outside cover.
    • The wires for the switch need to be tied back into the wires that lead to the battery. If needed, use electrical tape.
終わりに
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Antonio
メンバー登録日: 09/26/12
120 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S1G3
4 メンバー
6のガイドは作成済み
2 件のコメント
Any source for the switch?
Mark Bell - 返信
Thanks to this great post, I replaced my Breville BKC700XL On/Off Switch. The momentary switch is JR Products 12815 Black SPST Mini Mom-On/Off Switch, $8 on Amazon. https://www.amazon.com/dp/B002UC6QY0?psc...
Now, my Breville single serve is like new. I almost ordered a new machine, then I found ifixit. Kudos to you guys.
Boyd Gilbert - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 16
過去 30 日: 31
今までの合計 3,558
