はじめに
Replacing the heating tank should it fail to work.
必要な工具と部品
Use a Phillips #0 screwdriver to remove the following ten screws:
Four 18mm Phillips screws.
Four 9.75mm Phillips screws.
Two 8mm Phillips screws.
Use a Phillips #0 screwdriver to remove the following six screws:
Six 14.5mm Phillips screws.
Remove the power cord from the groove. (the black cord that leads into the green wire.)
Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
Push down on the hook and carefully move the hose from its grip.
2 の人々がこのガイドを完成させました。
