メインコンテンツにスキップ
Breville BKC600XL Heating Tank Replacement
必要な工具と部品
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 手順 1、 3の画像 1 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 手順 1、 3の画像 2 Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: 手順 1、 3の画像 3
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: 手順 2、 2の画像 1 Breville BKC600XL Heating Tank Replacement, Black Water Inlet: 手順 2、 2の画像 2
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: 手順 3、 2の画像 1 Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: 手順 3、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: 手順 4、 2の画像 1 Breville BKC600XL Heating Tank Replacement, Power Cord: 手順 4、 2の画像 2
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: 手順 5、 2の画像 1 Breville BKC600XL Heating Tank Replacement, Clear Hose: 手順 5、 2の画像 2
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: 手順 6、 1の画像 1
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Antonio
メンバー登録日: 09/26/12
120 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012人のメンバー
CPSU-PROPEN-F12S1G3
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 21
今までの合計 4,594
