メインコンテンツにスキップ
Brentwood TS-292B Browning Dial Circuitboard Replacement
必要な工具と部品
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 手順 1、 3の画像 1 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 手順 1、 3の画像 2 Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: 手順 1、 3の画像 3
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: 手順 2、 2の画像 1 Brentwood TS-292B Browning Dial Circuitboard Replacement: 手順 2、 2の画像 2
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: 手順 3、 1の画像 1
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: 手順 4、 2の画像 1 Brentwood TS-292B Browning Dial Circuitboard Replacement: 手順 4、 2の画像 2
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: 手順 5、 2の画像 1 Brentwood TS-292B Browning Dial Circuitboard Replacement: 手順 5、 2の画像 2
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
終わりに
作成者
3人の作成者と共同で作成されました。
Elly Ayala
メンバー登録日: 09/21/18
739 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S8-G7, Riccardelli Fall 2018 University of North Texas, Team S8-G7, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S8G7
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 231
