はじめに
This guide will show how to remove and replace the bread grabber of the Brentwood TS-292B.
  1. Remove all 6mm screws with the Phillips #2 screwdriver from the bottom of the toaster Remove all 6mm screws with the Phillips #2 screwdriver from the bottom of the toaster
    • Remove all 6mm screws with the Phillips #2 screwdriver from the bottom of the toaster
  2. Pull lever tab away from the toaster with force (after pushing in the small tab located to the left) Remove toaster cover carefully Remove toaster cover carefully
    • Pull lever tab away from the toaster with force (after pushing in the small tab located to the left)
    • Remove toaster cover carefully
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  4. Detach the bundled cable connector by carefully pulling it away from the circuit board
    • Detach the bundled cable connector by carefully pulling it away from the circuit board
  5. Make sure to keep toasting lever down Undo tabs with metal spudger on both sides
    • Make sure to keep toasting lever down
    • Undo tabs with metal spudger on both sides
    • Pinch and carefully remove from toaster
まとめ
Elly Ayala
メンバー登録日: 2018年09月21日
739 ポイント
5のガイドは作成済み
チーム
University of North Texas, Team S8-G7, Riccardelli Fall 2018 University of North Texas, Team S8-G7, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S8G7
4 メンバー
5のガイドは作成済み
統計データを表示:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 6
今までの合計 87
