メインコンテンツにスキップ
Braven BRV-X Battery Replacement
必要な工具と部品
  1. Braven BRV-X Battery Replacement, Bottom Outer Casing: 手順 1、 3の画像 1 Braven BRV-X Battery Replacement, Bottom Outer Casing: 手順 1、 3の画像 2 Braven BRV-X Battery Replacement, Bottom Outer Casing: 手順 1、 3の画像 3
    • Flip the Braven BRV-X upside down so you are facing the bottom side.
    • With the H1.5 Head Screwdriver, unscrew the four screws.
    • All screws on this device can be stripped easily. Hold your screwdriver with the thumb on top and swivel with the opposite hand's thumb and index finger.
    • Using the #0 Phillips screwdriver, unscrew the four screws on the four corners of the bottom side.
    • Gently remove the outer casing, which should reveal the inner shell.
    I have the Braven XXL that is just over 12 Months old. The Battery no longer charges and Zagg (bought out Braven) is offering me a $30 gift card since I’m out of warranty, no thanks. Do you know how I can replace the battery for this unit.
    Thanks
    Greg Beckler - 返信
  2. Braven BRV-X Battery Replacement: 手順 2、 2の画像 1 Braven BRV-X Battery Replacement: 手順 2、 2の画像 2
    • With a Jimmy, cut the two warranty seals on either side.
    • You may also use a tech knife instead of a Jimmy.
    • WARNING: Once warranty seals are broken, you may no longer return the product.
    • Next, remove the 18 screws with a #00 Phillips screwdriver.
  3. Braven BRV-X Battery Replacement: 手順 3、 2の画像 1 Braven BRV-X Battery Replacement: 手順 3、 2の画像 2
    • Using two plastic opening tools, slide under the cover and slowly lift.
    • There is glue nearly all around the inner shell, so strength will be necessary. When both tools are inserted, you can slide out along the edges.
  4. Braven BRV-X Battery Replacement, Battery: 手順 4、 1の画像 1
    • Remove the black foam squares from the red, yellow, and black wire on the top right side of the device.
  5. Braven BRV-X Battery Replacement: 手順 5、 3の画像 1 Braven BRV-X Battery Replacement: 手順 5、 3の画像 2 Braven BRV-X Battery Replacement: 手順 5、 3の画像 3
    • Now that the three wires are exposed, follow the wires to the white base that is plugged into the motherboard.
    • Using the tech knife, carefully remove the glue that keeps the plug in place.
    • Using the tweezers, carefully disconnect the plug from the motherboard.
    • WARNING: Make sure the battery is drained of all power for safety reasons.
    • There should still be a small white base attached to the motherboard, where the plug will eventually be plugged back in.
  6. Braven BRV-X Battery Replacement: 手順 6、 1の画像 1
    • The battery's black shell is connected to the motherboard with four screws. Use the #00 Phillips screwdriver to remove the four screws.
    • The screws near the speaker side of the device will be a tight squeeze to get to.
  7. Braven BRV-X Battery Replacement: 手順 7、 1の画像 1
    • Now, you should be able to lift the battery along with the black container up.
    • Pull the battery pack straight out so you do not damage other wires or the motherboard.
  8. Braven BRV-X Battery Replacement: 手順 8、 1の画像 1
    • Slide the blue battery out from the black container. Your battery is now removed from the device and is ready for replacement.
終わりに
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Courtney Crockett
メンバー登録日: 09/29/15
324 ポイント
2のガイドは作成済み
チーム
Texas Tech, Team 19-4, Rauch Fall 2015 Texas Tech, Team 19-4, Rauch Fall 2015人のメンバー
TTU-RAUCH-F15S19G4
4 メンバー
2のガイドは作成済み
10 件のコメント
Thank you for the replacement steps - do you know where I could buy a replacement battery?
jmckeag7 - 返信
Anyone ever figure out what battery they needed?
Aaron Eisenbarth -
I also would love to know what battery is actually needed for this.
grenchpickle - 返信
The batteries are two 18650's in tandem. You can get these from batteries plus
nick - 返信
Parallel or series connection?
Vladimir Skrbic -
What is the MAh on the required batteries for this device?
Doyle Redwine - 返信
The best batteries are the panasonic 18650 batteries. Do a google search for them. You can usually find them for $8-10 (and higher) each with a little work. The Panasonic brand is definitely more expensive but of superior quality to all the chinese knock off batteries. Will hold a charge better and last much longer on a charge. You will have to connect the batteries and do a little soldering before fitting them back in the container. Two 2600 mAh batteries would equal the OEM rating on this device of 5200 mAh.
Doyle Redwine - 返信
The batteries are in Parallel to give 3.7v, and 6800mah (or whatever amp ratting batteries you buy)
Paul Lambert - 返信
18650”s are too big
Patrick Walsh - 返信
Good lord this was a chore. Thanks for the writeup!
Jamie Watts - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 38
今までの合計 10,296
