メインコンテンツにスキップ
Braven BRV-1s Speaker Wire Replacement
必要な工具と部品
  1. Braven BRV-1s Speaker Wire Replacement, Outer Casing: 手順 1、 1の画像 1
    • To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
  2. Braven BRV-1s Speaker Wire Replacement: 手順 2、 1の画像 1
    • Using a metal spudger, gently pry the side of the defective case.
  3. Braven BRV-1s Speaker Wire Replacement: 手順 3、 1の画像 1
    • Still using the metal spudger, continue to work your way around the outer case.
  4. Braven BRV-1s Speaker Wire Replacement: 手順 4、 1の画像 1
    • Remove the broken outer case. Replace with used/new out case.
    • Note that unless properly sealed with glue, the speaker will no longer be water resistant.
  5. Braven BRV-1s Speaker Wire Replacement, Speaker Cone: 手順 5、 1の画像 1
    • To remove the speaker cone plate, remove 10 phillips screws (Phillips #00 headtype, 9.3mm long)
  6. Braven BRV-1s Speaker Wire Replacement: 手順 6、 1の画像 1
    • Using a metal spudger, gently pry the side of the defective speaker cone plate.
    • Remember to pry all around the side of the speaker cone plate.
    • Keep in mind that the adhesive will make it difficult to pry the plate off. To loosen the adhesive, heat the plate with a device such as a hair dryer.
  7. Braven BRV-1s Speaker Wire Replacement: 手順 7、 2の画像 1 Braven BRV-1s Speaker Wire Replacement: 手順 7、 2の画像 2
    • Remove the broken speaker cone plate. Replace with used/new out plate.
  8. Braven BRV-1s Speaker Wire Replacement, Speaker Wire: 手順 8、 1の画像 1
    • Once outer cover and speak cone/cover are removed, locate speaker wires
    • Each speaker has two wires: 1 red wire, 1 black wire
    • Check each wire for damage or if it has been disconnected from the speaker terminal
  9. Braven BRV-1s Speaker Wire Replacement: 手順 9、 3の画像 1 Braven BRV-1s Speaker Wire Replacement: 手順 9、 3の画像 2 Braven BRV-1s Speaker Wire Replacement: 手順 9、 3の画像 3
    • Once locating the damaged or disconnected wire, locate the proper speaker terminal to solder the wire to
    • On each speaker terminal you can see the (+) and a (-) next to each terminal. The black wire correlates to the (-) and the red wire correlates to the (+)
    • If necessary, use wire strippers to strip off some of the plastic casing at the end wire to expose the metal fibers
    • Using a soldering iron, carefully solder wire back to it's proper place on the speaker terminal
終わりに
To reassemble your device, follow these instructions in reverse order. You may need to refer to previous guides.
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Josh Matthias
メンバー登録日: 03/06/17
125 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G2, Harley Spring 2017 IUPUI, Team S2-G2, Harley Spring 2017人のメンバー
IUPUI-HARLEY-S17S2G2
4 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 896
