メインコンテンツにスキップ
Braven BRV-1s Auxiliary Ports Replacement
必要な工具と部品
  1. Braven BRV-1s Auxiliary Ports Replacement, Auxiliary Ports: 手順 1、 2の画像 1 Braven BRV-1s Auxiliary Ports Replacement, Auxiliary Ports: 手順 1、 2の画像 2
    • Please be aware that dismantling your Braven BRV-1s will make it cease to be waterproof.
    • Using a 0mm Philips Head screwdriver, unscrew the four 0.9mm screws located on the bottom of your device.
  2. Braven BRV-1s Auxiliary Ports Replacement: 手順 2、 2の画像 1 Braven BRV-1s Auxiliary Ports Replacement: 手順 2、 2の画像 2
    • Opening the Braven BRV-1s is very difficult as the case is glued shut. If need be, use a heat pad or other device to heat up and melt the glue.
    • Take a metal spudger and insert it into the bottom seam.
    • Work the spudger around the bottom seam making sure that bottom of the speaker is no longer glued onto the rest of the speaker.
  3. Braven BRV-1s Auxiliary Ports Replacement: 手順 3、 1の画像 1
    • Pry upward on the spudger until the bottom of the speaker is removed.
    • This is very difficult. Be sure to pry with care and avoid prying towards yourself. You will want to pry away from yourself in case the metal spudger suddenly becomes loose.
  4. Braven BRV-1s Auxiliary Ports Replacement: 手順 4、 1の画像 1
    • Underneath the bottom of the case you will find a passive radiator.
    • Using a 0mm Philips Head screwdriver, unscrew the 10 0.6mm screws located around the outside of the woofer.
  5. Braven BRV-1s Auxiliary Ports Replacement: 手順 5、 1の画像 1
    • This area is glued down as well. Use a heat pad or other heating device if needed.
    • Insert the metal spudger between the seam of the woofer.
    • Glide the spudger around the seam to loosen the woofer and get rid of excess glue.
  6. Braven BRV-1s Auxiliary Ports Replacement: 手順 6、 1の画像 1
    • Pull upward on the woofer until it is removed.
  7. Braven BRV-1s Auxiliary Ports Replacement: 手順 7、 1の画像 1
    • Remove the foam padding located in the Braven BRV-1s.
  8. Braven BRV-1s Auxiliary Ports Replacement: 手順 8、 1の画像 1
    • Using a 0mm Philips Head screwdriver unscrew the three 0.6mm screws on the auxiliary circuit board.
  9. Braven BRV-1s Auxiliary Ports Replacement: 手順 9、 1の画像 1
    • Push the circuit board via the outer auxiliary ports out of the speaker.
    • You may wish to use a tool to push the circuit board out via one of the auxiliary ports.
  10. Braven BRV-1s Auxiliary Ports Replacement: 手順 10、 1の画像 1
    • Soldering irons get extremely hot. Be sure to wear proper protective wear and keep it away from exposed skin while it is turned on.
    • Turn your soldering iron on to high.
  11. Braven BRV-1s Auxiliary Ports Replacement: 手順 11、 2の画像 1 Braven BRV-1s Auxiliary Ports Replacement: 手順 11、 2の画像 2
    • You may wish to use a heat gun to melt excess glue around the wires.
    • Using the soldering iron, desolder the wires from the circuit board.
  12. Braven BRV-1s Auxiliary Ports Replacement: 手順 12、 1の画像 1
    • Once you have soldered the glue off, remove the wires by pulling upwards.
終わりに
作成者
3人の作成者と共同で作成されました。
Jai Blair
メンバー登録日: 09/28/15
233 ポイント
1ガイドが承認済み
チーム
Eastern Washington University, Team 1-2, Matresse Fall 2015 Eastern Washington University, Team 1-2, Matresse Fall 2015人のメンバー
EWU-MATRESSE-F15S1G2
2 メンバー
3のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,290
