必要な工具と部品
To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
To remove the button registers, unscrew the two Phillips #00 bit type, 6 mm screws found on both sides of the control registers.
もう少しです!
終わりに
コメント 1 件
Great guide! Do you know the spec/name of the button registers so that I can purchase a new one to replace a dysfunctional one?
