はじめに
A damaged or disconnected battery can cause unreliable device functionality. One can reference this guide to learn how to successfully replace the battery found within the device and avoid nonexistent battery life.
必要な工具と部品
To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
To remove the battery, unscrew the 2 Phillips #00 bit type, 9 mm long screws on both sides of the battery.
