メインコンテンツにスキップ
Braven BRV-1M Battery Replacement
必要な工具と部品
  1. Braven BRV-1M Battery Replacement, Outer Casing: 手順 1、 1の画像 1
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Braven BRV-1M Battery Replacement: 手順 2、 1の画像 1
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Battery Replacement: 手順 3、 1の画像 1
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Braven BRV-1M Battery Replacement: 手順 4、 1の画像 1
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
  5. Braven BRV-1M Battery Replacement, Motherboard: 手順 5、 1の画像 1
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
  6. Braven BRV-1M Battery Replacement: 手順 6、 1の画像 1
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
  7. Braven BRV-1M Battery Replacement: 手順 7、 1の画像 1
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
  8. Braven BRV-1M Battery Replacement: 手順 8、 1の画像 1
    • Once disconnected, carefully remove the motherboard by pulling upwards.
  9. Braven BRV-1M Battery Replacement, Battery: 手順 9、 1の画像 1
    • To remove the battery, unscrew the 2 Phillips #00 bit type, 9 mm long screws on both sides of the battery.
  10. Braven BRV-1M Battery Replacement: 手順 10、 1の画像 1
    • Gently pull the battery from the housing of the device while disconnecting the red, white and black wires coming from the battery.
終わりに
作成者
1人の作成者と共同作成されました。
Erik Oliva
メンバー登録日: 02/14/18
607 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018人のメンバー
USFT-EYESTONE-S18S2G1
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 30
過去 30 日: 47
今までの合計 2,274
