メインコンテンツにスキップ
Braun Satin Hair 3 Hairdryer Disassembly
必要な工具と部品
  1. Braun Satin Hair 3 Hairdryer Disassembly, Hairdryer: 手順 1、 2の画像 1 Braun Satin Hair 3 Hairdryer Disassembly, Hairdryer: 手順 1、 2の画像 2
    • Before disassembly, unplug the device.
    • Make sure the device was not on for the last 10 minutes, because it might still be hot.
    • Using a Spanner 4.0 screwdriver, unscrew the 1.5mm screw from the exterior of the hairdryer.
  2. Braun Satin Hair 3 Hairdryer Disassembly: 手順 2、 3の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 2、 3の画像 2 Braun Satin Hair 3 Hairdryer Disassembly: 手順 2、 3の画像 3
    この手順で使用する道具:
    Jimmy
    $7.95
    • Begin at the cord end of the product. Gently pry the two halves of the external casing open with the help of a Jimmy and push the front cap up and away from the external casing. The snap-fit should come loose.
    • After opening the first snap-fit, remove the gray cord protector by slightly pulling it backwards while keeping the gap open with your other hand.
    • Slide the cord protector down the electrical cord and out of the way.
  3. Braun Satin Hair 3 Hairdryer Disassembly: 手順 3、 3の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 3、 3の画像 2 Braun Satin Hair 3 Hairdryer Disassembly: 手順 3、 3の画像 3
    この手順で使用する道具:
    iFixit Opening Picks (Set of 6)
    • Continue loosening the front cap from the external casing using the Jimmy. The snap-fits tend to snap back in place, so to prevent that use opening picks to keep the separated halves from snapping back closed.
    • Work your way around the product, opening one snap-fit at a time.
    • Take care while opening the snap-fits. If done gently, damaging the product can be prevented. It might take some time and patience, but prevents breaking the casing as a whole.
    • It is advised to open the snap-fits that are easier to access, and finish with the snapfits in the harder-to-reach spots, namely those in the area where the handle meets the head of the hairdryer (shown in the third picture).
  4. Braun Satin Hair 3 Hairdryer Disassembly: 手順 4、 3の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 4、 3の画像 2 Braun Satin Hair 3 Hairdryer Disassembly: 手順 4、 3の画像 3
    • Places where the snap-fits are located. Those are the most important points for opening it.
  5. Braun Satin Hair 3 Hairdryer Disassembly: 手順 5、 2の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 5、 2の画像 2
    • After opening the last snap-fit of the front cap, it comes loose from the external case halves. Slide the front cap off the external casing and put it aside.
  6. Braun Satin Hair 3 Hairdryer Disassembly: 手順 6、 2の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Using either tweezers or pliers, pinch and remove the sliders and button from the front cap.
    • The sliders can only be removed at the specific place, marked in the second picture. Here the slit is a bit wider, making it possible to push the sliders through.
  7. Braun Satin Hair 3 Hairdryer Disassembly: 手順 7、 1の画像 1
    • Using the same driver as before, remove the 1.5mm Spanner 4.0 screw that becomes accessible after removal of the front cap.
  8. Braun Satin Hair 3 Hairdryer Disassembly: 手順 8、 2の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 8、 2の画像 2
    この手順で使用する道具:
    iFixit Opening Tool
    $1.99
    • At the back of the product, the two halves of the case are connected with a snap-fit cap. Loosen this cap by putting a screwdriver or other opening tool under the cap using it as a lever.
    • Unfortunately, to further access the insides of the product, it is necessary to break the snap-fit cap. There is no way to reach this part from the back.
  9. Braun Satin Hair 3 Hairdryer Disassembly: 手順 9、 3の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 9、 3の画像 2 Braun Satin Hair 3 Hairdryer Disassembly: 手順 9、 3の画像 3
    • Using the same tools and methods as before, pry the two external halves open the rest of the way.
    • The snap-fits joining these two halves are tougher than those of the front cap. You might need to use more force to release them.
  10. Braun Satin Hair 3 Hairdryer Disassembly: 手順 10、 3の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 10、 3の画像 2 Braun Satin Hair 3 Hairdryer Disassembly: 手順 10、 3の画像 3
    • Unscrew the third and last 1.5mm spanner 4.0 screw keeping the fan down, using the same spanner driver again.
    • Unscrew the 1.3mm Phillips #2 screw holding the circuit board down, using a Phillips #2 screwdriver or bit.
    • Slide out the inner components as a whole.
  11. Braun Satin Hair 3 Hairdryer Disassembly: 手順 11、 2の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 11、 2の画像 2
    この手順で使用する道具:
    Phillips #1 Screwdriver
    $5.49
    • Separate the black inner casing from the other parts by removing the three 1.4mm Phillips #1 screws with a Phillips #1 screwdriver or bit and sliding it off.
  12. Braun Satin Hair 3 Hairdryer Disassembly: 手順 12、 2の画像 1 Braun Satin Hair 3 Hairdryer Disassembly: 手順 12、 2の画像 2
    • Pull apart the fan from the heating element and the circuit board.
    • This is the furthest this tear down can go without needing to solder it back together during reassembly.
終わりに
9 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Pim van der Werff
メンバー登録日: 03/07/18
385 ポイント
1ガイドが承認済み
チーム
8 Guide Comments
Do never open it…
It’s a disaster!
ZK A - 返信
Thanks a lot. It’s hard to disassemble without cosmetic damage(
Lessandro Kalmykoff - 返信
Thanks a lot. It worked for me. It's a shame they don't make it with a removable rear guard to remove hair build up on the fan. A bit of cosmetic damage but cleaned up with a sharp knife
cwhetter - 返信
Good job, exactly the info I needed. I would say difficulty is higher as it is almost impossible to execute this without damaging the edges.
Andras - 返信
Thanks a lot for the great description. I succeeded in repairing my hairdryer. The fan stopped spinning at the highest speed due to hairs caught in it. I removed them. Btw. I used tools for reparing a mobile phone which were very useful. I will add some pictures where I put crosses on the casing just to get an idea where the snap-fit caps are located. It helps to concentrate on these areas. I also succeeded in not breaking the snap-fit cap : )
K Mueller - 返信
Thanks! Now "successful"...
Step 5 was essential to me (did it too late), the last snap-fit of the front cap, it removes the whole case...
I repaired a satin hair 5. Afterwards I "flattened" and fitted the edges and grooves with a knife ("round" handle and blade)
Grandmastachief - 返信
Thanks for informing but did not inoformed the the manufacturer put something like glue to seal it bcz they want it not repairable just use it and throw it but I fix it very hardly.only the problem comes some hair caught in the blower I request to the manufacturer please put some type of net on the air intake side.
Thanks
Sarwar Fazal - 返信
Excellent instructions, Tell me where are the spare parts for this hair dryer?
Aleksandr A - 返信
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 102
過去 30 日: 404
今までの合計 16,417
