はじめに
Use this guide to remove and replace the batteries in the Braun Cruzer 6 - Beard and Hair Trimmer, Model: 5417
必要な工具と部品
Remove the trimmer head.
Remove the two Torx T5 screws attaching the cover to the hand-piece.
Remove the cover.
Take this opportunity to remove built up hair and residue. Hair can prevent the batteries from making contact leading to power failure.
Remove the back cover.
Using a flat head screw driver, remove the single screw holding the power board in place.
Use compressed air to clean the motor. Take this opportunity to lubricate the trimmer with an anti-rust spray or WD-40.
Remove the two AAA batteries by soldering them with soldering iron and des soldering pump.
Bend the terminals of the new batteries and solder them back in the right direction
If the batteries are already slightly charged, you can briefly press the power button to check if the motor is working
Insert the board again, with the side towards the motor first
23 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
7 件のコメント
Your guide saved me from purchasing a new device.
After replacing the batteries it works again like a charm!
Thanks this was helpful. The Braun Series 3 Hair Clipper HC3050 has a VERY similar design. Some additional notes: After removing the screws, it takes a bit of force to get the back separated from the front. I had to gently pry it apart with a screw driver. The very inside is slightly different, but same concept.
Die Anleitung war sehr hilfreich.
Der Austausch der Batterien ging ziemlich gut.
I think one pcc— 1.2 V 1800 mah AA battary
Thank you! Another appliance reborn :)
It really helps to work around consumerism with such shared knowledge!
Keep it up 👍
Guten Tag.
wo genau löte ich den Akku ab und wieder an?
Auf der Platine oder am Akku selber?
Gruß Tino
tino laube - 返信
Thanks a lot, as someone before, you saved me from buying a new one. Circular eonomy rocks ;)
I think I already posted a comment but I can’t see it.
Your excellent guide saved me from purchasing a new beard trimmer. After replacing the batteries it works again like a charm!
Thank you
King Arthur - 返信
Thank you so much. Another appliance reborn :)
Not so much on the price but regarding the consumerism avoidance.
Keep it up 👍
Pedro Faria - 返信
