メインコンテンツにスキップ
Braun Aromaster KF440 Internal Tubing Replacement Guide
必要な工具と部品
  1. Braun Aromaster KF440 Internal Tubing Replacement Guide, Access the base: 手順 1、 1の画像 1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the nut: 手順 2、 1の画像 1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the cover: 手順 3、 1の画像 1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove first tubing from one-way valve: 手順 4、 1の画像 1
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve located in the center. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
    • The piece will remain attached to the center plate for now.
  5. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove second tubing from hose: 手順 5、 1の画像 1
    • Using the larger plastic opening tool, gently push the tubing off of the valve located on the side. (If the tubing is being stubborn and won't come off, run the Spudger tool around the inside of tubing to free it up.)
  6. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove tubing from center plate: 手順 6、 1の画像 1
    • Using the larger plastic opening tool, gently push the tubing off of the center plate. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove filter basket housing: 手順 7、 1の画像 1
    • Grab the filter basket housing firmly.
    • Lift upwards on the filter basket housing. You may need to use one hand to hold the body of the coffee maker in place in order to remove the piece.
  8. Braun Aromaster KF440 Internal Tubing Replacement Guide, Locate latches: 手順 8、 1の画像 1
    • Locate the two plastic latches on the inside of the coffee maker.
  9. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the top: 手順 9、 3の画像 1 Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the top: 手順 9、 3の画像 2 Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove the top: 手順 9、 3の画像 3
    • Wedge the plastic opening tool between the back of the coffee maker and its top.
    • Once the top is loose remove by lifting up on the top of the coffee maker.
  10. Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove tube from the lid: 手順 10、 3の画像 1 Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove tube from the lid: 手順 10、 3の画像 2 Braun Aromaster KF440 Internal Tubing Replacement Guide, Remove tube from the lid: 手順 10、 3の画像 3
    • Once the top is removed you will notice that there is a tube attached.
    • Remove the tube from the lid by using the opening tool.
    • Place the opening tool under the clasp and gently lift the plastic clasps.
  11. Braun Aromaster KF440 Internal Tubing Replacement Guide, Detach tube: 手順 11、 1の画像 1
    • Finally, firmly hold the tube. Wiggle the black component away from the tube by hand.
  12. Braun Aromaster KF440 Internal Tubing Replacement Guide, Tubes are ready for replacement: 手順 12、 1の画像 1
    • You now have your tubes removed and ready to be replaced.
終わりに
作成者
3人の作成者と共同で作成されました。
Darcy Groom
メンバー登録日: 10/19/14
343 ポイント
3のガイドは作成済み
チーム
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G12
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 44
今までの合計 3,244
