メインコンテンツにスキップ
Braun Aromaster KF440 Heating Element Replacemen
必要な工具と部品
  1. Braun Aromaster KF440 Heating Element Replacemen, Access the base: 手順 1、 1の画像 1
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 Heating Element Replacemen, Remove the nut: 手順 2、 1の画像 1
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 Heating Element Replacemen, Remove the cover: 手順 3、 1の画像 1
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 Heating Element Replacemen, Remove the first center tube from the one-way valve: 手順 4、 2の画像 1 Braun Aromaster KF440 Heating Element Replacemen, Remove the first center tube from the one-way valve: 手順 4、 2の画像 2
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of the tubing to free it up.)
  5. Braun Aromaster KF440 Heating Element Replacemen, Remove second tubing from hose: 手順 5、 2の画像 1 Braun Aromaster KF440 Heating Element Replacemen, Remove second tubing from hose: 手順 5、 2の画像 2
    • Using the larger plastic opening tool, gently push the tubing off of the second one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of the tubing to free it up.)
  6. Braun Aromaster KF440 Heating Element Replacemen, Locate two wires: 手順 6、 1の画像 1
    • Looking at bottom of the coffee maker, locate the two gray wires attached to the circuit board.
  7. Braun Aromaster KF440 Heating Element Replacemen, Remove wires.: 手順 7、 3の画像 1 Braun Aromaster KF440 Heating Element Replacemen, Remove wires.: 手順 7、 3の画像 2 Braun Aromaster KF440 Heating Element Replacemen, Remove wires.: 手順 7、 3の画像 3
    • Remove each wire by gripping with pliers and then gently pulling straight up.
    • If you're having a hard time getting the wires off, gently wiggle the wire end back and forth with the pliers while keeping sufficient downward force on the circuit board with your finger. The wire should pop off easily.
  8. Braun Aromaster KF440 Heating Element Replacemen, Locate switch wires: 手順 8、 1の画像 1
    • Locate the second set of attached wires, which are connected to the on/off switch.
  9. Braun Aromaster KF440 Heating Element Replacemen, Remove switch wires: 手順 9、 3の画像 1 Braun Aromaster KF440 Heating Element Replacemen, Remove switch wires: 手順 9、 3の画像 2 Braun Aromaster KF440 Heating Element Replacemen, Remove switch wires: 手順 9、 3の画像 3
    • Notice that there are 4 wires to remove.
    • Remove each wire by gently gripping with pliers and then pulling straight back.
    • Again, if your having a hard time removing the wires, revert back to the tip given in step 4.
  10. Braun Aromaster KF440 Heating Element Replacemen, Pull away heating element: 手順 10、 1の画像 1
    • Once everything is detached, the heating element should come right out.
  11. Braun Aromaster KF440 Heating Element Replacemen, Remove bolts and nuts: 手順 11、 2の画像 1 Braun Aromaster KF440 Heating Element Replacemen, Remove bolts and nuts: 手順 11、 2の画像 2
    • Remove the bolt by simply screwing it off by hand, or by using the pliers again if you need to.
    • Remove the metal spacer. ( Note: Make sure you are aware which way it came off because it does matter when you go to reassemble)
    • Remove the wing nut.
  12. Braun Aromaster KF440 Heating Element Replacemen, Separate heating element from heating plate: 手順 12、 2の画像 1 Braun Aromaster KF440 Heating Element Replacemen, Separate heating element from heating plate: 手順 12、 2の画像 2
    • Pull the heating element off of the heating plate.
終わりに
ある他の人がこのガイドを完成しました。
作成者
6人の作成者と共同で作成されました。
Dennis
メンバー登録日: 10/20/14
315 ポイント
2のガイドは作成済み
チーム
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S8G12
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 36
今までの合計 4,126
