メインコンテンツにスキップ
Bowers and Wilkins T7 Speaker Driver Replacement
必要な工具と部品
  1. Bowers and Wilkins T7 Speaker Driver Replacement, Access Panel: 手順 1、 1の画像 1
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Speaker Driver Replacement: 手順 2、 1の画像 1
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Speaker Driver Replacement: 手順 3、 2の画像 1 Bowers and Wilkins T7 Speaker Driver Replacement: 手順 3、 2の画像 2
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Speaker Driver Replacement: 手順 4、 2の画像 1 Bowers and Wilkins T7 Speaker Driver Replacement: 手順 4、 2の画像 2
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Speaker Driver Replacement: 手順 5、 3の画像 1 Bowers and Wilkins T7 Speaker Driver Replacement: 手順 5、 3の画像 2 Bowers and Wilkins T7 Speaker Driver Replacement: 手順 5、 3の画像 3
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
  6. Bowers and Wilkins T7 Speaker Driver Replacement, Speaker Driver: 手順 6、 2の画像 1 Bowers and Wilkins T7 Speaker Driver Replacement, Speaker Driver: 手順 6、 2の画像 2
    • Remove the 7mm screws around the speaker using a J100 Phillips head screwdriver.
    • There are 4 screws in total around each speaker.
  7. Bowers and Wilkins T7 Speaker Driver Replacement: 手順 7、 1の画像 1
    • Now that all the screws are removed, pull straight up on the speaker drive to remove the speaker drive component.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Oluwagbemisola Aderibigbe
メンバー登録日: 02/27/17
230 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S7-G1, Cagle Spring 2017 USF Tampa, Team S7-G1, Cagle Spring 2017人のメンバー
USFT-CAGLE-S17S7G1
5 メンバー
4のガイドは作成済み
2 件のコメント
Where do you buy the replacement driver?
nigellittledesignandmedia - 返信
Tôi có cùng một câu hỏi? Tôi sẽ phải mua chúng ở đâu.
Phương Trần - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 21
今までの合計 2,127
