メインコンテンツにスキップ
Bowers and Wilkins T7 Battery Replacement
必要な工具と部品
  1. Bowers and Wilkins T7 Battery Replacement, Access Panel: 手順 1、 1の画像 1
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Battery Replacement: 手順 2、 1の画像 1
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Battery Replacement: 手順 3、 2の画像 1 Bowers and Wilkins T7 Battery Replacement: 手順 3、 2の画像 2
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Battery Replacement: 手順 4、 2の画像 1 Bowers and Wilkins T7 Battery Replacement: 手順 4、 2の画像 2
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Battery Replacement: 手順 5、 3の画像 1 Bowers and Wilkins T7 Battery Replacement: 手順 5、 3の画像 2 Bowers and Wilkins T7 Battery Replacement: 手順 5、 3の画像 3
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
  6. Bowers and Wilkins T7 Battery Replacement, Battery: 手順 6、 1の画像 1
    • Using a cutting tool such as a Jimmy steel blade or wire cutter, cut the cable tie surrounding the battery.
    • Be careful not to damage the battery while cutting the cable tie surrounding the battery.
  7. Bowers and Wilkins T7 Battery Replacement: 手順 7、 2の画像 1 Bowers and Wilkins T7 Battery Replacement: 手順 7、 2の画像 2
    • Using the ifixit Opening Tool, pry out the battery power supply connector.
    • Pull and remove the battery power supply connector.
  8. Bowers and Wilkins T7 Battery Replacement: 手順 8、 2の画像 1 Bowers and Wilkins T7 Battery Replacement: 手順 8、 2の画像 2
    • After disconnecting the power supply connector, pull the battery out of its case.
終わりに
8 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Bertrand Plummer
メンバー登録日: 02/28/17
251 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S7-G1, Cagle Spring 2017 USF Tampa, Team S7-G1, Cagle Spring 2017人のメンバー
USFT-CAGLE-S17S7G1
5 メンバー
4のガイドは作成済み
3 件のコメント
Bravo ! Le choix de cet appareil symbolique !
Pierre Vanhoorenbeeck - 返信
Seriously
Couldn't the lady get her
'nails did’
Lux Valet - 返信
No repair any repairing sentar
Abdul Malik Parvez - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 21
過去 30 日: 119
今までの合計 9,399
