メインコンテンツにスキップ
Bowers and Wilkins T7 Access Panel Replacement
必要な工具と部品
  1. Bowers and Wilkins T7 Access Panel Replacement, Access Panel: 手順 1、 1の画像 1
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Access Panel Replacement: 手順 2、 1の画像 1
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Access Panel Replacement: 手順 3、 2の画像 1 Bowers and Wilkins T7 Access Panel Replacement: 手順 3、 2の画像 2
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Access Panel Replacement: 手順 4、 2の画像 1 Bowers and Wilkins T7 Access Panel Replacement: 手順 4、 2の画像 2
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Access Panel Replacement: 手順 5、 3の画像 1 Bowers and Wilkins T7 Access Panel Replacement: 手順 5、 3の画像 2 Bowers and Wilkins T7 Access Panel Replacement: 手順 5、 3の画像 3
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Shane R. Cowper
メンバー登録日: 03/02/17
131 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S7-G1, Cagle Spring 2017 USF Tampa, Team S7-G1, Cagle Spring 2017人のメンバー
USFT-CAGLE-S17S7G1
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 25
今までの合計 2,676
