メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bowers and Wilkins P5 Headphones Driver Replacement
必要な工具と部品
  1. Bowers and Wilkins P5 Headphones Driver Replacement, Driver: 手順 1、 1の画像 1
    • Remove the earpads from your P5s.
    • Removed driver in centre.
    FixBotに聞いてみる
    コメントを追加
  2. Bowers and Wilkins P5 Headphones Driver Replacement: 手順 2、 1の画像 1
    • Each side uses three Phillips screws, which are covered in fabric. You can either gently scrape away the fabric in the areas indicated, or insert your driver directly. I did the former but it can bunch up the fabric.
    • This is the right side.
    FixBotに聞いてみる
    コメントを追加
  3. Bowers and Wilkins P5 Headphones Driver Replacement: 手順 3、 1の画像 1
    • This is the left side.
    FixBotに聞いてみる
    コメントを追加
  4. Bowers and Wilkins P5 Headphones Driver Replacement: 手順 4、 2の画像 1 Bowers and Wilkins P5 Headphones Driver Replacement: 手順 4、 2の画像 2
    • Gently flip each driver area to the side - it will still be connected to the headband with two soldered wires.
    • De-solder each wire to fully separate the driver area. (Already completed and driver removed in this step.)
    FixBotに聞いてみる
    コメントを追加
  5. Bowers and Wilkins P5 Headphones Driver Replacement: 手順 5、 1の画像 1
    • The drivers are inconveniently glued in place, but can be relatively easily removed with some elbow grease.
    • I used an iOpener to soften the glue, along with a Jimmy and metal spudger to score the glue around the circumference.
    • Each driver area has a cutout section, as indicated, which will assist you with prying out the driver.
    • Try to work the driver out only by its sides. I pushed my metal spudger underneath and pried upward and damaged the driver grille.
    FixBotに聞いてみる
    コメントを追加
  6. Bowers and Wilkins P5 Headphones Driver Replacement: 手順 6、 1の画像 1
    • Swap the working driver from one set to the other set and solder it in place.
    • Voila!
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order and solder the new driver back in place.
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Jon
メンバー登録日: 07/16/14
1,002 ポイント
4のガイドは作成済み
1件のガイドコメント
Necesito comprar las bocinas de mis auriculares P5,
Dónde puedo comprarlos?
Gracias
Andrés L - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 50
今までの合計 4,955
