メインコンテンツにスキップ
Bottom Board Removal
必要な工具と部品
  1. Bottom Board Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: 手順 1、 1の画像 1
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Bottom Board Removal: 手順 2、 1の画像 1
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Bottom Board Removal: 手順 3、 3の画像 1 Bottom Board Removal: 手順 3、 3の画像 2 Bottom Board Removal: 手順 3、 3の画像 3
    • Grab the top shell of the mouse and lift up to remove.
  4. Bottom Board Removal: 手順 4、 1の画像 1
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Bottom Board Removal: 手順 5、 2の画像 1 Bottom Board Removal: 手順 5、 2の画像 2
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
  6. Bottom Board Removal, Side Panels: 手順 6、 2の画像 1 Bottom Board Removal, Side Panels: 手順 6、 2の画像 2
    • Locate the 5 mm silver flat head mounting screws (2) to the left and right of the scroll wheel and remove with the Phillips #1 screwdriver.
  7. Bottom Board Removal: 手順 7、 2の画像 1 Bottom Board Removal: 手順 7、 2の画像 2
    • Locate the snaps on the bottom corners of the mouse side panels and pop the indicated snaps out, using a spudger or your fingernail.
  8. Bottom Board Removal: 手順 8、 3の画像 1 Bottom Board Removal: 手順 8、 3の画像 2 Bottom Board Removal: 手順 8、 3の画像 3
    • Repeat Step 6 for the opposite side panel in order to detach both sides from the base of the mouse.
  9. Bottom Board Removal: 手順 9、 2の画像 1 Bottom Board Removal: 手順 9、 2の画像 2
    • Grab the sides of the mouse and lift them up to detach from the base of the mouse.
  10. Bottom Board Removal, Bottom Board: 手順 10、 2の画像 1 Bottom Board Removal, Bottom Board: 手順 10、 2の画像 2
    • Pop the scroll wheel out of the snap holding it in place. You can use your finger or a spudger to do so.
  11. Bottom Board Removal: 手順 11、 2の画像 1 Bottom Board Removal: 手順 11、 2の画像 2
    • Locate the four 5 mm black flat head screws on the corners of the bottom board.
    • Unscrew these four black screws.
  12. Bottom Board Removal: 手順 12、 3の画像 1 Bottom Board Removal: 手順 12、 3の画像 2 Bottom Board Removal: 手順 12、 3の画像 3
    • Lift the bottom board up to remove from its mounting posts. This will separate it completely from the bottom panel of the mouse.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
royceeklund
メンバー登録日: 01/18/13
115 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 18-36, Regan Winter 2013 Cal Poly, Team 18-36, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S18G36
3 メンバー
30のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 26
過去 30 日: 54
今までの合計 5,567
