メインコンテンツにスキップ
Bose Wave Radio AWR1-1W Speaker Replacement
必要な工具と部品
  1. Bose Wave Radio AWR1-1W Speaker Replacement, Base: 手順 1、 2の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement, Base: 手順 1、 2の画像 2
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 2、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 2、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 2、 3の画像 3
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 3、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 3、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 3、 3の画像 3
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 4、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 4、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 4、 3の画像 3
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 5、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 5、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 5、 3の画像 3
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 6、 1の画像 1
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 手順 7、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 手順 7、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement, Front Grill: 手順 7、 3の画像 3
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 8、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 8、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 8、 3の画像 3
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 9、 1の画像 1
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 手順 10、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 手順 10、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement, Speakers: 手順 10、 3の画像 3
    • Remove a total of eight 15mm Phillips #2 screws surrounding each speaker.
  11. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 11、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 11、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 11、 3の画像 3
    • Gently pull each speaker out of the device.
  12. Bose Wave Radio AWR1-1W Speaker Replacement: 手順 12、 3の画像 1 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 12、 3の画像 2 Bose Wave Radio AWR1-1W Speaker Replacement: 手順 12、 3の画像 3
    • Pull the wire connected to the speakers out of the device.
    • You already disconnected this wire from the inside of the device earlier.
終わりに
6 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Cassie Harriman
メンバー登録日: 04/18/17
1,033 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S15-G2, Banghart Spring 2017 Cal Poly, Team S15-G2, Banghart Spring 2017人のメンバー
CPSU-BANGHART-S17S15G2
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 46
今までの合計 7,090
