メインコンテンツにスキップ
Bose Soundlink Revolve Bottom Circuit Board Replacement
必要な工具と部品
  1. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: 手順 1、 2の画像 1 Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board Access: 手順 1、 2の画像 2
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve Bottom Circuit Board Replacement: 手順 2、 3の画像 1 Bose Soundlink Revolve Bottom Circuit Board Replacement: 手順 2、 3の画像 2 Bose Soundlink Revolve Bottom Circuit Board Replacement: 手順 2、 3の画像 3
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve Bottom Circuit Board Replacement: 手順 3、 2の画像 1 Bose Soundlink Revolve Bottom Circuit Board Replacement: 手順 3、 2の画像 2
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve Bottom Circuit Board Replacement: 手順 4、 2の画像 1 Bose Soundlink Revolve Bottom Circuit Board Replacement: 手順 4、 2の画像 2
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: 手順 5、 3の画像 1 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: 手順 5、 3の画像 2 Bose Soundlink Revolve Bottom Circuit Board Replacement, AUX/USB Port: 手順 5、 3の画像 3
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
  6. Bose Soundlink Revolve Bottom Circuit Board Replacement, Bottom Circuit Board: 手順 6、 1の画像 1
    • Remove the yellow tape over the location where the ribbon from the central speaker meets the bottom circuit board.
    • Use the blue plastic opening tool to pry up the black latch holding down the ribbon.
    • Remove the motherboard from the device.
終わりに
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Brian Butner
メンバー登録日: 09/27/17
912 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S6-G2, Remmell Fall 2017 USF Tampa, Team S6-G2, Remmell Fall 2017人のメンバー
USFT-REMMELL-F17S6G2
4 メンバー
4のガイドは作成済み
43件のガイドコメント
I need the ribbon because it is damage, can you sell one to me?
My email is ttegil@hotmail.com can you send me the way I can buy it.
Kind regards
Gilberto - 返信
Hello do toi fond thé ribbon because i have thé same problème .
M'y email adresse thualromain44.rt@gmail.com
Thanks you
romain thual -
Hi I need bottom circuit board for bose revolve , could you sale it for me. mail: seawolf1974@mail.ru , delivery to Spain
kindly regards
seawolf1974 - 返信
I need bottom circuit board for Bose revolve, can I get it available in Nigeria, @sullivaniheme@gmail.com
Sullivan - 返信
Hey there, I also require the bottom circuit board for my Bose Revolve sam.rowlands@hotmail.com
Sam - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 33
過去 30 日: 239
今までの合計 16,603
