はじめに
If you are experiencing problems with your Soundlink III's functioning such that the device won't turn on or certain buttons won't work, your motherboard may need replacement.
必要な工具と部品
Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
Remove the bottom panel.
easy peasy. great instructions!
couple things: 1. you dont need to remove the rubber pads completely; just enough to get the screws in & out. 2. if you get a small screw driver with the battery, its crap. use your own.
thank you ifixit for another great tutorial.
scott
ある他の人がこのガイドを完成しました。
コメント 1 件
Hi, I have to replace my SLIII motherboard.
The question is. Where can I get one ?
