はじめに
If your SoundLink III exhibits significantly decreased battery life or no longer takes a charge, you may need a new battery. In this guide, you will learn how to open up your Bose Soundlink III and replace the battery.
必要な工具と部品
Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
Remove the bottom panel.
easy peasy. great instructions!
couple things: 1. you dont need to remove the rubber pads completely; just enough to get the screws in & out. 2. if you get a small screw driver with the battery, its crap. use your own.
thank you ifixit for another great tutorial.
scott
38 の人々がこのガイドを完成させました。
25 件のコメント
Hello, I wonder where I could buy a raplacement battery for my Bose Soundlink III. (I'm from Belgium)
Thanks for the response.
Gabriel, ik heb Bose gecontacteerd en ze zeggen dat ze dat niet apart verkopen. Het enigste wat ik heb gevonden is dit:http://www.ecrater.com/p/25268626/batter...
Of als het nog onder garantie valt, gewoon terug opsturen.
Gabrial, I've contacted Bose and they say that they didn't sell them seperately. The only thing that I've found is this:http://www.ecrater.com/p/25268626/batter...
If it still falls under warranty, send the speaker back.
yea i'm also interested to buy bose soundlink 3 battery hurmmm where could i get it....
Yes please, where do you get replacement batteries (I'm from Australia and Bose here want to charge me $149 to remove and replace 4 screws!)
I want to buy also. I'm here in Saudi arabia dammam
My bose SL3 just stopped working so I thought maybe a charge...nothing ..charge indicator just pulses yellow and doesn't do anything no other lights will turn on anytime and won't charge or play ..was fine till instantly..done
I purchase a replacement battery for your bose Soundlink 3 from Amazon.It work well.You could purchase it on Amazon.
im from the uk is there anywhere in England I can buy a battery for the bose soundlink 3 please
just contact sales@sfelectronics.biz they have them for 20 bucks
I’ve changed the battery (easy) but now battery indicator light keeps flashing red ? What’s going on
Here is a link to new batteri for your soundlink 3 3 years warranty and good price as well
I'm from fiji, battery indicator keeps flashing red,what does that mean
Bought the replacement battery on Amazon. Used this video guide to replace. Went without a hitch. Thanks Dakoda.
:( Sorry only now I saw your answer
i found this battery if anyone needs it…. 19 eur
Thank you for a straightforward and comprehensive guide. My first time at this and it was as easy as changing a regular torch battery, only with an extra screw or two.
Thanks, Dakota! I followed your instructions and found them to be accurate and complete. I thank you for them. There are various sellers on Ebay for these replacement batteries.
Del Tucker - 返信
Perfect instructions!! Thanks!!
