メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bose Soundlink II Battery Replacement
必要な工具と部品
  1. Bose Soundlink II Battery Replacement, Bose Soundlink II Cover Removal: 手順 1、 1の画像 1
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Battery Replacement: 手順 2、 1の画像 1
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Battery Replacement, Battery: 手順 3、 1の画像 1
    • Using the screwdriver with the T-10 star tip, remove the 6.75 mm. screws marked in red.
  4. Bose Soundlink II Battery Replacement: 手順 4、 2の画像 1 Bose Soundlink II Battery Replacement: 手順 4、 2の画像 2
    • Carefully remove the battery by pulling it out of the speaker.
終わりに
18 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Kevin Bailey
メンバー登録日: 09/24/15
512 ポイント
2のガイドは作成済み
チーム
Texas Tech, Team 22-4, Rauch Fall 2015 Texas Tech, Team 22-4, Rauch Fall 2015人のメンバー
TTU-RAUCH-F15S22G4
3 メンバー
5のガイドは作成済み
11件のガイドコメント
Where i can buy one them battery model?
Daniel Campos - 返信
Just ordered a “Used, in good shape”, and it seems to be, however, it’s the REALLY original model, with the solid flap on the front, that turns into the stand. SN: 054867920870604AE. Guessing this is NOT the “Soundlink II”, but the original model. Instructions that came with it claim battery will last up to 3 hours. JUST IN CASE this battery is shot, was looking into what’s involved to replace it. However, mine being older, wondering if this battery would still fit?
      Thanks, Bob.
bobveitch4 - 返信
How do I get a used replacement battery for this in Nigeria? Please contact me on johnpaulokenyodo@gmail.com if any. Thanks
Okenyodo Johnpaul - 返信
I bought an Replacement battery which brand is Emaks from Amazon and do it following the guide,It works well now!Thank you!!!
Emily - 返信
How much the battery only
Joboy De Guzman II - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 53
過去 30 日: 299
今までの合計 37,027
