メインコンテンツにスキップ
Bose Soundlink Flex Battery Replacement
必要な工具と部品
  1. Bose Soundlink Flex Battery Replacement, Grille: 手順 1、 1の画像 1
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Battery Replacement: 手順 2、 1の画像 1
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Battery Replacement: 手順 3、 2の画像 1 Bose Soundlink Flex Battery Replacement: 手順 3、 2の画像 2
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
  4. Bose Soundlink Flex Battery Replacement, Battery: 手順 4、 3の画像 1 Bose Soundlink Flex Battery Replacement, Battery: 手順 4、 3の画像 2 Bose Soundlink Flex Battery Replacement, Battery: 手順 4、 3の画像 3
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
  5. Bose Soundlink Flex Battery Replacement: 手順 5、 3の画像 1 Bose Soundlink Flex Battery Replacement: 手順 5、 3の画像 2 Bose Soundlink Flex Battery Replacement: 手順 5、 3の画像 3
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
    • Pull the back panel off exposing the motherboard.
  6. Bose Soundlink Flex Battery Replacement: 手順 6、 2の画像 1 Bose Soundlink Flex Battery Replacement: 手順 6、 2の画像 2
    • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
    • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
  7. Bose Soundlink Flex Battery Replacement: 手順 7、 3の画像 1 Bose Soundlink Flex Battery Replacement: 手順 7、 3の画像 2 Bose Soundlink Flex Battery Replacement: 手順 7、 3の画像 3
    • Take the motherboard out and take note of the battery attached.
    • Remove the insulation and the solder from the wiring.
    • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
    • Solder the wires of the new battery onto the motherboard.
    • Be cautious when adding the solder to not damage the motherboard or burn yourself.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Kalvin Lee
メンバー登録日: 03/19/24
435 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024人のメンバー
UMASSD-SHADDIX-S24S4G1
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 66
過去 30 日: 291
今までの合計 2,036
