メインコンテンツにスキップ
Bose SoundTouch Portable Subwoofer Replacement
必要な工具と部品
  1. Bose SoundTouch Portable Subwoofer Replacement, Speaker Battery: 手順 1、 1の画像 1
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Subwoofer Replacement: 手順 2、 1の画像 1
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Subwoofer Replacement: 手順 3、 1の画像 1
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Subwoofer Replacement, Grille: 手順 4、 1の画像 1
    • Remove the two screws holding the speaker grille in place.
  5. Bose SoundTouch Portable Subwoofer Replacement: 手順 5、 1の画像 1
    • Grip the sides of the device and push the speaker grille down and out.
  6. Bose SoundTouch Portable Subwoofer Replacement: 手順 6、 1の画像 1
    • Gently release the ribbon from its connector and remove the grille.
  7. Bose SoundTouch Portable Subwoofer Replacement, Metal Trim: 手順 7、 1の画像 1
    • Remove the two screws using a torx screwdriver.
  8. Bose SoundTouch Portable Subwoofer Replacement: 手順 8、 1の画像 1
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  9. Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: 手順 9、 2の画像 1 Bose SoundTouch Portable Subwoofer Replacement, Subwoofer: 手順 9、 2の画像 2
    • Separate the case that holds the subwoofer in place.
    • Be careful when doing this step because there are several connectors inside.
  10. Bose SoundTouch Portable Subwoofer Replacement: 手順 10、 1の画像 1
    • Gently pull on the connectors at the circuit board to remove. Remove the screws from the circuit board and set the board aside.
  11. Bose SoundTouch Portable Subwoofer Replacement: 手順 11、 3の画像 1 Bose SoundTouch Portable Subwoofer Replacement: 手順 11、 3の画像 2 Bose SoundTouch Portable Subwoofer Replacement: 手順 11、 3の画像 3
    • Remove the four screws from the subwoofer and lift it out of the casing.
終わりに
作成者
3人の作成者と共同で作成されました。
Chelsea Martin
メンバー登録日: 02/20/17
703 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S1-G3, Leahy Spring 2017 USF Tampa, Team S1-G3, Leahy Spring 2017人のメンバー
USFT-LEAHY-S17S1G3
3 メンバー
10のガイドは作成済み
2 件のコメント
Thanks a lot for sharing your incredible ideas. It is an appreciated and pretty tip for all those music lovers. What a Fatal post for those who want to upgrade an existing subwoofer with a new one.
About more: www.outdoorsumo.com
Outdoor Sumo - 返信
About more: ++https://compactcarsubwoofer.blogspot.com...
Outdoor Sumo - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 15
今までの合計 1,496
