メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Bose SoundTouch 20 Screen Replacement
必要な工具と部品
    1. Bose SoundTouch 20  Screen Replacement, Screen: 手順 1、 2の画像 1 Bose SoundTouch 20  Screen Replacement, Screen: 手順 1、 2の画像 2
      • Remove the (6) six 1.5 cm Phillips screws holding on the bottom cover of the speaker using a Phillips #0 screwdriver.
      • Lift the cover straight up and set the cover to the side.
      FixBotに聞いてみる
      コメントを追加
    2. Bose SoundTouch 20  Screen Replacement: 手順 2、 2の画像 1 Bose SoundTouch 20  Screen Replacement: 手順 2、 2の画像 2
      • Gently pull the white ribbon from the connector on the top side of the motherboard.
      • Make sure to pull straight back so you don't bend or damage the ribbon.
      FixBotに聞いてみる
      コメントを追加
    3. Bose SoundTouch 20  Screen Replacement: 手順 3、 2の画像 1 Bose SoundTouch 20  Screen Replacement: 手順 3、 2の画像 2
      • Remove the (4) four 1.5 cm screws connecting the motherboard to the speaker.
      • Remove the (2) two 1 cm screws connecting the motherboard to the speaker.
      • When lifting the board, be careful of the two ribbons located underneath the board. Don't lift the board straight up, instead tilt it towards the cables. As shown in picture 2.
      FixBotに聞いてみる
      コメントを追加
    4. Bose SoundTouch 20  Screen Replacement: 手順 4、 2の画像 1 Bose SoundTouch 20  Screen Replacement: 手順 4、 2の画像 2
      • Remove the white cable by pressing on the side of the connector with a tab and pulling backwards.
      FixBotに聞いてみる
      コメントを追加
    5. Bose SoundTouch 20  Screen Replacement: 手順 5、 2の画像 1 Bose SoundTouch 20  Screen Replacement: 手順 5、 2の画像 2
      • Gently pull the thinner white ribbon located towards the center of the board.
      • Pull straight down to prevent bending or damaging the ribbon.
      • Squeeze the plastic sides of the plug and pull straight down to remove this ribbon.
      • After removing the two ribbons, completely remove the motherboard and set it to the side.
      FixBotに聞いてみる
      コメントを追加
    6. Bose SoundTouch 20  Screen Replacement: 手順 6、 2の画像 1 Bose SoundTouch 20  Screen Replacement: 手順 6、 2の画像 2
      • To remove the side panel from the speaker, lift the top of the sides from the slots.
      • The sides will be bent up after removing from the slots, they do not come up right away.
      • After completing the previous step, pull gently straight up to remove the side.
      • Repeat on both sides of the speaker.
      FixBotに聞いてみる
      コメントを追加
    7. Bose SoundTouch 20  Screen Replacement: 手順 7、 3の画像 1 Bose SoundTouch 20  Screen Replacement: 手順 7、 3の画像 2 Bose SoundTouch 20  Screen Replacement: 手順 7、 3の画像 3
      • Remove the (2) two 1.5 cm screws circled in picture one.
      • Rotate the speaker to its side and remove the (2) two 1.5 cm screws circled in picture 2. Remove these screws on either side of the speaker.
      • After all screws are removed, gently remove the cover from the speaker as shown in picture 3.
      FixBotに聞いてみる
      コメントを追加
    8. Bose SoundTouch 20  Screen Replacement: 手順 8、 3の画像 1 Bose SoundTouch 20  Screen Replacement: 手順 8、 3の画像 2 Bose SoundTouch 20  Screen Replacement: 手順 8、 3の画像 3
      • After lifting the cover, you will see two ribbons attaching the cover to the speaker. Gently remove these ribbons by pulling straight down.
      • Make sure to pull the ribbons straight out so you don't bend or damage the ribbon.
      FixBotに聞いてみる
      コメントを追加
    9. Bose SoundTouch 20  Screen Replacement: 手順 9、 2の画像 1 Bose SoundTouch 20  Screen Replacement: 手順 9、 2の画像 2
      • Place the fully separated cover face down on a surface.
      • Using a star bit screwdriver, remove the (6) six screws circled in picture 1 to release the screen.
      • Gently push out the screen from the front of the cover.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Felipe Cordeiro Bof
メンバー登録日: 09/26/17
197 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S11-G3, Passmore Fall 2017 USF Tampa, Team S11-G3, Passmore Fall 2017人のメンバー
USFT-PASSMORE-F17S11G3
4 メンバー
21のガイドは作成済み
2件のガイドコメント
Hi !
Where can I buy the screen ? I can’t find it anywhere
acp62 - 返信 共有
What symptoms? Is it only the display no longer working or does the whole system not power up?
Siegfried Loeffler - 返信 共有
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 35
過去 30 日: 84
今までの合計 7,203
