メインコンテンツにスキップ
Bose SoundTouch 10 Back panel Replacement
必要な工具と部品
  1. Bose SoundTouch 10 Back panel Replacement, Front Panel: 手順 1、 1の画像 1
    • Turn the speaker over so that the rubber strips along the bottom are facing you.
    • Use the iFixit Opening Tool to peel back the rubber strip on the bottom-front edge.
  2. Bose SoundTouch 10 Back panel Replacement: 手順 2、 1の画像 1
    • Use a #2 Phillips screwdriver to remove each of the three 20mm screws on the bottom front edge of the speaker.
  3. Bose SoundTouch 10 Back panel Replacement: 手順 3、 2の画像 1 Bose SoundTouch 10 Back panel Replacement: 手順 3、 2の画像 2
    • Slide the front panel with the mesh covering downwards to disconnect it from the SoundTouch 10 body.
    • Lift the panel away to reveal the speaker head.
  4. Bose SoundTouch 10 Back panel Replacement, Back panel: 手順 4、 1の画像 1
    • Use a #2 Phillips screwdriver to remove each of the six 20mm screws located underneath the front panel.
  5. Bose SoundTouch 10 Back panel Replacement: 手順 5、 1の画像 1
    • Flip the speaker onto its back.
    • Loosen the adhesive by sliding a Metal Spudger under the edge where the back panel meets the speaker's body.
  6. Bose SoundTouch 10 Back panel Replacement: 手順 6、 2の画像 1 Bose SoundTouch 10 Back panel Replacement: 手順 6、 2の画像 2
    • Use force with an iFixit Plastic Opening Tool to pry the back panel up from the speaker frame.
    • If the panel does not come free easily, a heat gun may be needed to weaken the adhesive.
    • Once the panel has been disconnected, it should fall open revealing the motherboard.
  7. Bose SoundTouch 10 Back panel Replacement: 手順 7、 2の画像 1 Bose SoundTouch 10 Back panel Replacement: 手順 7、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use ESD Safe Tweezers (Blunt Nose) to pull out the wire ribbon at the end of the motherboard.
  8. Bose SoundTouch 10 Back panel Replacement: 手順 8、 2の画像 1 Bose SoundTouch 10 Back panel Replacement: 手順 8、 2の画像 2
    • The motherboard contains capacitors (shown as cylinders in the upper right of the picture) which can hold a charge even when the speaker is powered off. Do not touch them as doing so may result in a shock.
    • Pull up on the base of the speaker wire plug to disconnect it from the motherboard.
終わりに
4 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
James Asbury
メンバー登録日: 04/10/17
898 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S13-G1, Forte Spring 2017 Cal Poly, Team S13-G1, Forte Spring 2017人のメンバー
CPSU-FORTE-S17S13G1
4 メンバー
5のガイドは作成済み
コメント 1 件
How can I install a 12v battery?
Quique - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 11
過去 30 日: 39
今までの合計 6,599
