はじめに
Use this guide to replace the front or back mesh grilles. Make sure you have the required tools. The first time you remove a grille might be a little difficult due to some glue holding it in place. Be careful when removing, as the grille may bend easily.
必要な工具と部品
Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
Repeat steps to remove the back grille.
Attention à la longueur des vis (les 4 vis du côté du circuit sont les 4 plus longue) et si vous vous trompez et plaçez ces 4 vis ailleurs vous risquez de les briser et que le bout de celles-ci demeurera dans la partie du chassis.
9 の人々がこのガイドを完成させました。
6 件のコメント
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Steps are wrong and difficult. Try taking out from somewhere between the center, it will automatically pull the locks out which are located on the sides.
Woher bekomme ich nun rin solches Vorder- und Rückgitter?
[COBS]CR4ZY BLITZ - 返信
