はじめに
The battery is located on the bottom of the speaker underneath a rubber protective cover. Use this guide to replace a faulty battery in your SoundLink Mini. Check what model battery your your SoundLink Mini has before purchasing a replacement.
必要な工具と部品
Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
87 の人々がこのガイドを完成させました。
60 件のコメント
Were can we I get the battry to order ... need it badly pls m.
I need the battry for soundlink mini ... pls were can I get it
Battery can be ordered with the link below
