メインコンテンツにスキップ
Bose SoundLink Mini ボタンスイッチ用回路基板の交換
必要な工具と部品
  1. Bose SoundLink Mini ボタンスイッチ用回路基板の交換, バッテリー: 手順 1、 1の画像 1
    • ゴム製のバッテリー・カバーをめくり、T8 Torxスクリュードライバーを使って、赤い丸印が付けられた6.0mmのネジを4本外してください。
    Help I removed the part which I'm not supposed to next to the battery charger how do I put it back?
    Sooraj murali - 返信
    Where can I actually get a replacement battery????
    appreciate any help bc I couldn’t find it anywhere.
    Kamil M. - 返信
    Where can I get an actual replacement battery???
    Kamil M. - 返信
    Hi Brent and thank you for this easy fix.
    Still I have a problem I did not have while the original battery was in place: the sound is now buzzing even at a middle-of-the-range volume.
    I used the original screws and everything seems in place and the screws are tightened “right” I would say. I am usually fine fixing things. And I do not see what I could have done wrong…
    Any suggestion?
    Thank you.
    MBP - 返信
    Which battery is the correct one. Two model are shown to be purchase
    Ruben Roman - 返信
    What is not discussed is the wires that connect the battery to the speaker. In mine, I think I destroyed the speaker, because I pulled out the battery and dislodged the wires from the electronic board. I think they must have been soldered on, and now am having trouble attaching the new wires to the board.
    horseylawgal - 返信
    I have lost the 4 battery screws. What size are they? I think they are metric but what is the length? They were Philips head flat as I remember.
    Wolfgang Mitchell - 返信
  2. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 2、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 2、 2の画像 2
    • カバーを後ろで固定しながら、バッテリーを真っすぐに引っ張り上げて、取り出します。
    Where can I buy this battery
    Karsten lou nielsen - 返信
    Well that part was simple. What I need is how to disconnect the ribbon cable which is soldered in on both ends. No help here.
    Art Kennedy - 返信
    soweit sogut..aber die Kabel sind verlötet ?
    das ist ja das problem
    also sehr schlechte Anleitung da ja das wichtigste fehlt !!
    Armin Karl - 返信
    Bonjour pas aussi simple car les câbles de la batterie d origine sont soudés…
    Lionel Ludosky - 返信
    On remark though: the original Bose battery has a thin foam gasket at the base. This foam gasket makes sure the room behind the speakers is airtight, which is essential for a clean sound. Most aftermarket batteries do not have this gasket, leading to a thumping noise when you turn up the music. This is easy to fix: with a sharp cutter, gently peel the gasket from the original battery and reinstall is on the new battery. That solved the problem for me. Alternatively, you can cut a think sheet of PE foam to fit the base of battery.
    philippe.bleiman - 返信
    Cable is not soldered on BOSE SoundLink Mini!
    The situation is different on BOSE SoundLink Mini II. The procedure to replace battery is more demanding as the cable is soldered.
    france.gartner - 返信
    iFixit日本語版からこのバッテリーパーツの購入ボタンを押すと、米国サイトにリンクされていて、当然ながらバッテリーは米国内以外では買えません!となります。何のための購入ボタンなんでしょうかね。時間の無駄でした。
    Shon DuBois - 返信
  3. Bose SoundLink Mini ボタンスイッチ用回路基板の交換, フロント/背面保護グリル: 手順 3、 1の画像 1
    • メタル製スパッジャーをアルミケースとグリルのゴム状エッジの間に差し込みます。
    • 画像のようにメタル製スパッジャーを配置します。
    Woher bekomme ich nun rin solches Vorder- und Rückgitter?
    [COBS]CR4ZY BLITZ - 返信
  4. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 4、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 4、 2の画像 2
    • 2つのタブがカチっと音がして外れるまで、ゆっくりとグリルをこじ開けます。
    • グリルが曲がってしまうので、作業はゆっくりと丁寧に行なってください。
  5. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 5、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 5、 2の画像 2
    • グリルは、両面接着テープでスピーカーに取り付けられています。グリルを取り外すには、右側に張力をかけながら、上方にゆっくりと引っ張ります。
    • グリルが曲がらないように、ゆっくりと作業を進めてください。
  6. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 6、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 6、 2の画像 2
    • 裏側のグリルも同じようにして、外します。
    Attention à la longueur des vis (les 4 vis du côté du circuit sont les 4 plus longue) et si vous vous trompez et plaçez ces 4 vis ailleurs vous risquez de les briser et que le bout de celles-ci demeurera dans la partie du chassis.
    Pierre Payette - 返信
  7. Bose SoundLink Mini ボタンスイッチ用回路基板の交換, バッテリーカバー: 手順 7、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換, バッテリーカバー: 手順 7、 2の画像 2
    • T8トルクスドライバーを使って、右側の長さ9.0 mmネジを4本、左側の長さ15.0 mmを4本外します。
    le circuit de gauche ci-contre a les 4 vis de 15 mm prenez-en note.
    Pierre Payette - 返信
  8. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 8、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 8、 2の画像 2
    • 人差し指で基板を図の方向に押しながら、ナイロンや金属製のスパッジャーで持ち上げて取り外します。
  9. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 9、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 9、 2の画像 2
    • 電池カバーを慎重に引っ張り、ゴム製のタブがアルミニウム製のケースから滑り落ちるまで引っ張ります。
    I just want to emphasize that the rubber tab (that is part of the cover) is supposed to sit ON TOP of the circuit board. In my case, my son managed to pull of the battery cover off completely, so as I was taking it apart I didn’t see how the rubber tab was actually supposed to sit inside the box. Because these instructions have you unseat the circuit board, I thought it was implying the tab was supposed to sit under the circuit board. But that is NOT the case! If I had looked at the pictures 7 and 9 more carefully, I would have seen how things were supposed to sit. Instead I first jammed things back together with the rubber underneath the board (really hard to do), only to find that the slightly squeezed rubber tab pushed the cover out a millimeter so it wouldn’t sit right on the charger. On closer inspection, I figured things out.
    Matthew Busche - 返信
  10. Bose SoundLink Mini ボタンスイッチ用回路基板の交換, ボタンスイッチ用回路基板: 手順 10、 1の画像 1
    • スポンジを取り外し(後の交換のために保管)、黒いタブを90度回転させて、コネクタのリボンケーブルへのグリップをゆっくりと外します。リボンケーブルをコネクタから取り出します。
    • 再組立て時にリボンケーブルを再インストールするには、黒いタブをめくり上げる必要があります。
    there’s supposed to be a wire strips lock behind that small,gray foam,careful fellas don’t end it like me,i just simply pulling it off until it teared apart the board, also it broked,and until know i haven’t fix it yet
    Kikay CianancyTM - 返信
    Button Switch Circuit Board is cut in my speaker what I do for it
    bodapati pramchand1997 - 返信
  11. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 11、 3の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 11、 3の画像 2 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 11、 3の画像 3
    • メタル製スパッジャーを使って、プラスティックの仕切りをこじ開けます。
  12. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 12、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 12、 2の画像 2
    • プラスチック製の仕切り板を取り外すときは、中に配線されているワイヤを傷つけないように注意してください。
  13. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 13、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 13、 2の画像 2
    • バッテリー用スペースの穴を通して手を伸ばし、画像のように電源タップを外します。
    Hi ineed complete surkit bord for bose sound link mini speaker
    Ajay kumar - 返信
    Bose sound link mini 1 complete surkit prece?
    Ajay kumar - 返信
    How many pins a ribbon wire
    Rio Aldene Frani - 返信
  14. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 14、 3の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 14、 3の画像 2 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 14、 3の画像 3
    • 両方の基板を上下に動かして、ケーシングから取り外します。
    • 接続されているスピーカーの配線を外し、両方の回路基板を完全に外してください。
    • スピーカーの配線を外すときは、白いコネクター部分を握ると配線が外れます。
  15. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 15、 2の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 15、 2の画像 2
    • ボタンスイッチの基板にクリップで装着されているスピーカーワイヤを外します。
  16. Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 16、 3の画像 1 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 16、 3の画像 2 Bose SoundLink Mini ボタンスイッチ用回路基板の交換: 手順 16、 3の画像 3
    • ナイロンやメタルのスパッジャーで、ボタンスイッチの回路基板を少し持ち上げてみてください。
    • ボタンスイッチ基板をケーシングからまっすぐ引き抜きます。
    Hi
    my bose SoundLink mini keep flashing ember light even it’s plugged into AC adapter,can you tell me how can I get it update
    Moqdam Aljwrany - 返信
    hi dear
    hpe you are fine .dear need me one IC of this divice if posiable please inform me .thanks
    Aamir MAlik - 返信
終わりに
デバイスを再組み立てする際は、これらの手順を逆の順番に従って作業を進めてください。
16 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
8人の作成者と共同で作成されました。
Jordan Smith
メンバー登録日: 10/01/15
895 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S1G23
4 メンバー
21のガイドは作成済み
12 件のコメント
Hello
Where I can buy circuit
candellaaria - 返信
Yes were can we get the replacement part? ?
sonny goddin - 返信
Hi sonny,
did you find this part ? (the first circuit board)
luc.lacouture -
Hi
Can you get the relacement part for the mini II or is it the same - and if
- where and how to order for delivery to Europe?
Andreas Burckhart - 返信
Kindly can you tell me is th bose Soundlink mini first generation has an update or not, because it started no charge and the ember ligy keep flashing and some times reed color , I bought a new battery but still the same now it’s playing up
SOLVED:
Hey, check the ends of the ribbon cables on the circuit board for corrosion where the cable goes in to the plug, as this is a common problem to why the batterys don't get enough charge, (yellow to red light to dead…)
Also, when the Batterys drain down to much… There is a low voltage cut off switch circuit board hidden in the battery pack. You must manually charge the battery past 7.4v for it to trigger “ON” power to the bose speaker (its a low voltage lipo fire battery protection feature thing).
However to do this… you must carefully crack the battery pack open and pull out the Batterys to get to the positive and negative terminals of the 2 lipo cells,
Do not try to charge the pack from the multi pin socket on the outside of the battery case… As the power goes through a circuit board before reaching the Batterys… Blow that and you might as well throw the whole battery in the bin, as that power management circuit board splits the power and has many micro chips… Just go straight for the battery cell.
justin meynell -
Hai moqdam, how after you changing the battery? You said now its playing up? What is that mean? Is it back to normal again?
reezkeywork -
Same thing here, can’t find replacement parts. I need to replace the input board.
deusmarjuninho - 返信
Merhaba, bir giriş kartı buldunuz mu? Ona ihtiyacım var. Nasıl bulabilirim?
Alaybeyi -
hello dear is posiable provide me this part i alreay upload that IC pic on ths page .
Aamir MAlik - 返信
It is very difficult to remove the grill and put it back in without bending it, even in the slightest, which will greatly affect the appearance. I think a bigger not should be made of this, and even a photo included of before and after, or a video of how it is done.
Courtney Moore - 返信
I dropped it in the sea. And it did not work. What is possible solution. Its almost 3 months now.
Ar-Ar - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 76
過去 30 日: 279
今までの合計 32,165
