はじめに
If you are experiencing any audio issues with the higher frequency sounds (the treble) such as distortion, muffling, quietness, or total absence of sound, you may need to replace one or more of your treble speakers.
必要な工具と部品
Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
Remove the bottom panel.
easy peasy. great instructions!
couple things: 1. you dont need to remove the rubber pads completely; just enough to get the screws in & out. 2. if you get a small screw driver with the battery, its crap. use your own.
thank you ifixit for another great tutorial.
scott
この手順で使用する道具:Tweezers$4.99
For each of the 4 treble speakers you must uncoil the red wire and black wire in order to remove them.
5 の人々がこのガイドを完成させました。
