はじめに
If you notice any major damage to your charging port that prevents you from charging your device, you may need to replace your charging port.
必要な工具と部品
Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
Remove the bottom panel.
easy peasy. great instructions!
couple things: 1. you dont need to remove the rubber pads completely; just enough to get the screws in & out. 2. if you get a small screw driver with the battery, its crap. use your own.
thank you ifixit for another great tutorial.
scott
Remove the two 12.5 mm screws on either side of the charging port using a Torx T10 screwdriver.
Gently unplug the cable connecting the charging port.
Now the charging port should be fully detached and ready for replacement.
Any luck with the aux port?
Cannot find board with replacement parts
7 の人々がこのガイドを完成させました。
15 Guide Comments
Hello, This is an excellent resource. One thing, you did not say, or I did not see, where to purchase the actual usb port. Where can I locate one and this would be for a Bose Soundlink II.
Thank you,
Jim
jp7868@gmail.com
HI, thanks a lot for the instructions, any idea where i acn purchase the charging port full part
thanks
Carlos
I would like to know where i can buy the replacement part
Also would love to know where to purchase the required replacement MicroUSB Port. I'm searching and if I find anything compatible I will contact anyone else who posts to this thread.
Hi.
Excellent step-by-step. Just the same question as the rest please
Agree with the rest of the comments about the instructions. I am writing from Mallorca, Spain, and I was just talking to the Bose service provider here and they were telling me the Soundlink III battery problem is common. The price for a new battery installed is around 140€ which for a product that costs between 250€- 290€ is nothing but normal. Lithium batteries and their useful life, nobody tells you about it when you buy their product.
ATM the issue is the charging port. Now part of these instructions will get you to battery you can buy a battery on Ebay or amazon $40.+usd make sure the battery is oem 2330mAh -same if you order from Alibaba.com/aliexpress .i buy/sell/repair mini I/ii/& the iii
I am also looking for a part. The instructions are irrelevant if a part is not available.
Parts for the sound link iii check Ebay/mouser/also once it’s out check some stereo shops -again Alibaba.com/Ali express
any link for this charging port replacement?
Ezar
ezralocs@gmail.com
Hello all,
Does anyone have the part number for the charging port?
Thanks.
Great troubleshooting section. However can you enlighten me as to the next step - if there is one?
My Bose sound Link III will not switch on. Nothing if battery alone. No lights or function with the AC power plugged in apart from the Bilip sound for power on or off but only via the power source not the switch on top left.
Is this motherboard or power generally?
Appreciate your guidance here.
Bill
Bose Model 414255, Part 369814-0040. Has anyone successfully found the part? I'm not an electrician, so I rather change the little motherboard, rather than the actual power port - avoid soldering it.
If anyone was able to get it fix, TIA if you can send me link where to find the parts.
albert288@hotmail.com
Albert Tom - 返信
The power port part is called "dc-044a". You can google it and find it on aliexpress for example. Hope this helped some of you.
