Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
These screws may be difficult to remove. If necessary, use a lever for extra torque.
Remove the bottom panel.
Gently peel back the adhesive padding on either side of the inner back panel.
The adhesive for these pads is powerful, but you may require new adhesive if the original begins to fail.
Remove four screws from each of the four speakers (16 screws total) using a Torx #10 screwdriver.
All screws (excluding the two middle screws on the right side) are 12.5 mm in length. The aforementioned middle screws are 21 mm.
Use a metal spudger to pry the device apart. You must use a metal spudger because of the great force necessary to pry it apart.
The circuitry for the buttons on the top panel may be found underneath, so use caution not to damage it.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
