はじめに
If you are experiencing any audio issues with the lower frequency sounds (the bass) such as distortion, muffling, quietness, or total absence of sound, you may need to replace your bass speaker.
必要な工具と部品
Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
Remove the bottom panel.
easy peasy. great instructions!
couple things: 1. you dont need to remove the rubber pads completely; just enough to get the screws in & out. 2. if you get a small screw driver with the battery, its crap. use your own.
thank you ifixit for another great tutorial.
scott
Remove the four 12.5 mm screws using a Philips #2 screwdriver.
You will now be able to remove the bass speaker.
5 の人々がこのガイドを完成させました。
2 Guide Comments
Where can I buy this bass speaker (Bose SoundLink III)?
