メインコンテンツにスキップ
Bose SoundLink III Bass Speaker Replacement
必要な工具と部品
  1. Bose SoundLink III Bass Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose SoundLink III Bass Speaker Replacement: 手順 2、 2の画像 1 Bose SoundLink III Bass Speaker Replacement: 手順 2、 2の画像 2
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
  3. Bose SoundLink III Bass Speaker Replacement: 手順 3、 1の画像 1
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose SoundLink III Bass Speaker Replacement: 手順 4、 2の画像 1 Bose SoundLink III Bass Speaker Replacement: 手順 4、 2の画像 2
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
  5. Bose SoundLink III Bass Speaker Replacement, Motherboard: 手順 5、 1の画像 1
    • Gently peel back the adhesive padding on either side of the inner back panel.
    • The adhesive for these pads is powerful, but you may require new adhesive if the original begins to fail.
  6. Bose SoundLink III Bass Speaker Replacement: 手順 6、 2の画像 1 Bose SoundLink III Bass Speaker Replacement: 手順 6、 2の画像 2
    • Remove the four 12.5 mm Phillips #2 screws mounting the outer case.
    • Slide off the outer case.
  7. Bose SoundLink III Bass Speaker Replacement: 手順 7、 1の画像 1
    • Remove four screws from each of the four speakers (16 screws total) using a Torx #10 screwdriver.
    • All screws (excluding the two middle screws on the right side) are 12.5 mm in length. The aforementioned middle screws are 21 mm.
  8. Bose SoundLink III Bass Speaker Replacement: 手順 8、 2の画像 1 Bose SoundLink III Bass Speaker Replacement: 手順 8、 2の画像 2
    • Remove the two 12.5 mm screws which mount the top panel using a Phillips #2 screwdriver.
    • Now you should be able to lift the top panel off.
  9. Bose SoundLink III Bass Speaker Replacement: 手順 9、 2の画像 1 Bose SoundLink III Bass Speaker Replacement: 手順 9、 2の画像 2
    • Use a metal spudger to pry the device apart. You must use a metal spudger because of the great force necessary to pry it apart.
    • The circuitry for the buttons on the top panel may be found underneath, so use caution not to damage it.
  10. Bose SoundLink III Bass Speaker Replacement: 手順 10、 1の画像 1
    • Remove the 12.5 mm screw mounting the motherboard using a Philips #2 screwdriver.
  11. Bose SoundLink III Bass Speaker Replacement: 手順 11、 1の画像 1
    • Gently disconnect the three cables connected to the motherboard.
    • Remove the motherboard from the device.
  12. Bose SoundLink III Bass Speaker Replacement, Bass Speaker: 手順 12、 2の画像 1 Bose SoundLink III Bass Speaker Replacement, Bass Speaker: 手順 12、 2の画像 2
    • Remove the four 12.5 mm screws using a Philips #2 screwdriver.
    • You will now be able to remove the bass speaker.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Dakoda Sanders
メンバー登録日: 02/04/16
1,516 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 3-2, Wollert Spring 2016 USF Tampa, Team 3-2, Wollert Spring 2016人のメンバー
USFT-WOLLERT-S16S3G2
4 メンバー
7のガイドは作成済み
2 件のコメント
Where can I buy this bass speaker (Bose SoundLink III)?
imoto.marcelo - 返信
Where do you get the bass speaker for the SL3?
Scott - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 29
過去 30 日: 82
今までの合計 7,443
