はじめに
As any device with a battery, the Bose SoundLink Color II will need a battery replacement once the battery no longer has the expected capacity.
However, because this speaker is waterproof, this task is not straightforward.
The following steps will guide you through the process of replacing the battery.
Keep in mind that waterproofness cannot be guaranteed once your device has been disassemble, but it is better than replacing the whole speaker no ?
必要な工具と部品
Commencez par tirer sur les bords extérieurs de la partie en caoutchouc sur le dessous de l'enceinte.
Notez qu'elle ne se détachera pas complètement de l'enceinte.
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
11 の人々がこのガイドを完成させました。
4件のガイドコメント
Please be advised that the Bose support website has a firmware update that fixes some battery issues. I took my dead - non-charging Soundlink Color II apart and then found the website and fixed the issue with the firmware update! The update website is located @ http://btu.bose.com
paul ramirez - 返信 共有
Beware that, after the battery gets undervolted (like 2.4V), the device does not seem to accept an externally charged battery and continues to act dead, until it finds some form of comfort over its USB input. Not from a dumb 5V power supply, but from an USB charger or PC supporting some level of power delivery extension, and an appropriately wired lead.
Stein Somers - 返信 共有
Please list type of battery and where to find it it took me a while to find it
Guide was good, the battery pcb i found in my unit was a bit different and had metal strips soldered to the board and welded to the battery.
