メインコンテンツにスキップ
Bose SoundDock XT Logic Board Replacement
必要な工具と部品
  1. Bose SoundDock XT Logic Board Replacement, Logic Board: 手順 1、 1の画像 1
    • Remove the six # 1 Phillips head screws from the bottom panel.
  2. Bose SoundDock XT Logic Board Replacement: 手順 2、 1の画像 1
    • After removing the bottom plate, you will have visibility of the logic board. Using a plastic opening tool, lift the small black latch holding the ribbon cable. Slide the ribbon cable loose from the logic board.
  3. Bose SoundDock XT Logic Board Replacement: 手順 3、 1の画像 1
    • Next, using pointed nose tweezers, remove the 4-wire white connector from the logic board by wiggle back and forth while lifting until the connector is disconnected from the board.
    • Metal pointed nose tweezers may cause damage if used improperly.
  4. Bose SoundDock XT Logic Board Replacement: 手順 4、 1の画像 1
    • Remove the remaining 8mm length # 2 Phillips head screws holding the motherboard in place.
  5. Bose SoundDock XT Logic Board Replacement: 手順 5、 2の画像 1 Bose SoundDock XT Logic Board Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    購入する
    • Record the order of the 6 wires soldered to the board.
    • Using a hot soldering iron and either a solder sucker or de-soldering wick, remove the solder from the 6 wires highlighted on the photo in red.
    • Soldering iron may cause damage to the device if used improperly.
  6. Bose SoundDock XT Logic Board Replacement: 手順 6、 1の画像 1
    • Replace old logic board with the new logic board. Place the wires into the solder holes and solder in place. Reassemble the SoundDock.
    • Make sure the wires are in the correct order using the recorded pattern from the wire removal step 3.
終わりに
To reassemble your device, follow these instructions in reverse order. With proper execution of these steps, you will be able to replace your logic board and enjoy the sound of your SoundDock XT.
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
redacted
メンバー登録日: 09/29/15
288 ポイント
2のガイドは作成済み
チーム
IUPUI, Team 1-4, Hagerty Fall 2015 IUPUI, Team 1-4, Hagerty Fall 2015人のメンバー
IUPUI-HAGERTY-F15S1G4
5 メンバー
3のガイドは作成済み
コメント 1 件
Hi, one question, where can i buy the replacement logic board?
Nahir Romero - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 2,158
