メインコンテンツにスキップ
Bose SoundDock Portable v2 Speaker Replacement
必要な工具と部品
  1. Bose SoundDock Portable v2 Speaker Replacement, Speaker: 手順 1、 3の画像 1 Bose SoundDock Portable v2 Speaker Replacement, Speaker: 手順 1、 3の画像 2 Bose SoundDock Portable v2 Speaker Replacement, Speaker: 手順 1、 3の画像 3
    • Gently pry the front mesh cover off of the SoundDock using a metal spudger.
    • The mesh is held on by small velcro strips so if you hear a tearing sound it is just the velcro coming apart
  2. Bose SoundDock Portable v2 Speaker Replacement: 手順 2、 2の画像 1 Bose SoundDock Portable v2 Speaker Replacement: 手順 2、 2の画像 2
    • Remove the four 16mm #2 screws holding the speaker to the base using a #2 screwdriver
    • Gently lift the speaker from the base.
    • Do not lift the speaker to far out of the base, you may damage the wires.
  3. Bose SoundDock Portable v2 Speaker Replacement: 手順 3、 1の画像 1
    • You will notice 2 coils of wire around the speaker's input tabs. Slide these coils off as un-winding the wires may break the wires. Slide the coils around your new driver.
終わりに
4 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Evan Low
メンバー登録日: 04/14/15
551 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G1
4 メンバー
5のガイドは作成済み
5 件のコメント
I am unsure of what to do in step #3…
Is the purpose to remove the speaker completely and place a brand new one? (Making sure not to pull the old speaker too far out as to not break any wire… ) ???
Edited comment:
I am not sure what they mean by "pins".
vero198099 - 返信
Hi I just accidently pushed in that dome part in the middle a little and now it distorts. I tried using a vacuum but it didnt work. Please help!!!!!!!!
AJ Grape - 返信
Try to see if there’s any way you can reduce the nozzle size of the vacuum cleaner you’re using - this should increase the flow rate, and possibly the amount of force applied over such a small area.
Alternatively, you can use a very very fine needle, bend the end of it, and use it to “hook” the cone. This method is really a last resort, as you want to avoid making even the smallest of holes.
Absolute last resort is replacing the speaker, which if you can find a replacement, should be pretty easy.
Colm Donnelly -
Need help love this speaker when it’s played loud it makes a load noise when the base is on changed aux lead think it’s the speaker what do I do
Chantelle Webb - 返信
How do you cut on without remote
Chad Davenport - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 32
今までの合計 11,716
