はじめに
If the ear pads on your Bose QuietComfort 35 headphones become worn down and begin to break down or tear, use this guide to replace the ear cushions and scrim mats.
Ear pads influence noise isolation and audio quality in addition to offering comfort and providing grip. Worn down ear pads will reduce noise isolation and will provide less comfort while using your headphones. Depending on how often you use your headphones, you will need to replace the ear pads every 18 months to 2 years.
Before beginning, make sure to power off your headphones completely and disconnect from any external power source.
必要な工具と部品
Align the cushion with the ear cup, and expose the plastic ring underneath the cushion by pulling the cushion back slightly.
Slide and press the plastic ring into the first clip until you hear a clicking sound. Repeat for the remaining clips.
Repeat the above steps for the second ear cushion.
Confirm that the ear cushions are secure.
7 の人々がこのガイドを完成させました。
