メインコンテンツにスキップ
Bose Portable Smart Speaker battery Replacement
必要な工具と部品
    • flip your speaker onto its back.
    • using your screwdriver, carefully remove the 4 screws holding the speaker together.
    • using a heat gun, heat the base until you can pry up into the speaker with the spludger.
    • be careful not to pry into the motherboard and speaker.
    • carefully using the spludger, carefully disconnect the charging port's wires that connect to the motherboard.
    • once you get into the speaker, unscrew the 6 screws that are holding the speaker in place.
    • be very careful as the speaker assembly is still attached to wires on the motherboard.
    • carefully grabbling the connector end, disconnect the wires that connect the speaker assembly to the motherboard.
    • when reassembling, apply the new waterproof seal before placing the speaker.
    • with the speaker assembly now removed, you should now be left with the motherboard and battery.
    • using the screwdriver, unscrew the 6 screws that are holding down the motherboard.
    • carefully pry up the motherboard using the spludger.
    • be very careful when prying as the motherboard is still connected to wires with the battery.
    • with the motherboard left to one side, carefully unplug the battery connector on the motherboard.
    • remove the battery.
    • using a pair of scissors, carefully cut a slit the sponge casing. you should now be able to remove the battery.
    • be VERY careful not to accidentally puncture the battery with the scissors.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
776831
メンバー登録日: 06/10/21
1,025 ポイント
8のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 68
今までの合計 1,954
