はじめに
These are Bose On-Ear headphones that I had previously repaired for some other issues. This time the left ear cushion got tore off. Replacement cushions were bought online for less that $10 USD and since it is a Bose, I figured I could spend that money. The replacement is straight forward and does not require any tools etc.
ツール
ツールは指定されていません。
パーツ
Here is the Bose Tricore OE headset. Slightly worn and a torn left ear cushion
To remove an existing ear cushion one would simply be applying a bit of force between the ear pads and the housing. The ear cushion will simply snap off
This shows the snaps that attach the ear pad to the case.
ある他の人がこのガイドを完成しました。
