はじめに
This guide will allow you to access the subwoofers on either side of the Bose Cinemate 10. By removing the end caps, you can clean them or replace the subwoofers.
必要な工具と部品
Using the blue plastic opening tool, pry up on the cloth covered end panel. The edge of end cap cover should separate from main body of device.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
