メインコンテンツにスキップ
Boosted Board 1st Generation Skateboard Bearings Replacement
必要な工具と部品
  1. Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: 手順 1、 2の画像 1 Boosted Board 1st Generation Skateboard Bearings Replacement, Rear Wheels: 手順 1、 2の画像 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 2、 1の画像 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 3、 2の画像 1 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 3、 2の画像 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 4、 3の画像 1 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 4、 3の画像 2 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 4、 3の画像 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: 手順 5、 2の画像 1 Boosted Board 1st Generation Skateboard Bearings Replacement, Skateboard Bearings: 手順 5、 2の画像 2
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 6、 3の画像 1 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 6、 3の画像 2 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 6、 3の画像 3
    • Use an Allen wrench to apply pressure to the inside edge of the bearing until it pops out
  7. Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 7、 3の画像 1 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 7、 3の画像 2 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 7、 3の画像 3
    • Replace bearing by dropping it in the center of the wheel and use a socket wrench to pop in back it place
  8. Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 8、 3の画像 1 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 8、 3の画像 2 Boosted Board 1st Generation Skateboard Bearings Replacement: 手順 8、 3の画像 3
    • Slide the bearing spacer on to an Allen wrench
    • Align the Allen wrench in the center of the bearing and drop the spacer directly in the middle
    • Repeat Step 7 for placing the bearing in this side of the wheel.
終わりに
To reassemble your device, follow these directions in reverse order.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Emily Imfeld
メンバー登録日: 10/06/16
532 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S15G7
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 18
今までの合計 763
