メインコンテンツにスキップ
Boosted Board 1st Generation Pulley Bearings Replacement
必要な工具と部品
  1. Boosted Board 1st Generation Pulley Bearings Replacement, Rear Wheels: 手順 1、 2の画像 1 Boosted Board 1st Generation Pulley Bearings Replacement, Rear Wheels: 手順 1、 2の画像 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Pulley Bearings Replacement: 手順 2、 1の画像 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Pulley Bearings Replacement: 手順 3、 2の画像 1 Boosted Board 1st Generation Pulley Bearings Replacement: 手順 3、 2の画像 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Pulley Bearings Replacement: 手順 4、 3の画像 1 Boosted Board 1st Generation Pulley Bearings Replacement: 手順 4、 3の画像 2 Boosted Board 1st Generation Pulley Bearings Replacement: 手順 4、 3の画像 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Pulley Bearings Replacement, Pulley Bearings: 手順 5、 2の画像 1 Boosted Board 1st Generation Pulley Bearings Replacement, Pulley Bearings: 手順 5、 2の画像 2
    • Use one finger to pull out the pulley bearing.
    • A good technique is to go around in a circle and lift from underneath the bearing in a carving motion.
  6. Boosted Board 1st Generation Pulley Bearings Replacement: 手順 6、 3の画像 1 Boosted Board 1st Generation Pulley Bearings Replacement: 手順 6、 3の画像 2 Boosted Board 1st Generation Pulley Bearings Replacement: 手順 6、 3の画像 3
    • Place the new pulley bearing inside the gear hole and use two fingers to push down evenly until it slides into place.
    • The bearing should be flush with the gear
終わりに
作成者
4人の作成者と共同で作成されました。
Emily Imfeld
メンバー登録日: 10/06/16
532 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S15G7
4 メンバー
6のガイドは作成済み
コメント 1 件
you mentioned cleaning bearings how do you go about that? (if rep[lacing not an option at moment) Also I noticed a single Large Bearing in my replacement kit, what is that and where do I replace it as I don’t see where it could be (I have a first Gen)
Rick Gram - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,572
