メインコンテンツにスキップ
Boosted Board 1st Generation Belts Replacement
必要な工具と部品
  1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: 手順 1、 2の画像 1 Boosted Board 1st Generation Belts Replacement, Rear Wheels: 手順 1、 2の画像 2
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Belts Replacement: 手順 2、 1の画像 1
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Belts Replacement: 手順 3、 2の画像 1 Boosted Board 1st Generation Belts Replacement: 手順 3、 2の画像 2
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Belts Replacement: 手順 4、 3の画像 1 Boosted Board 1st Generation Belts Replacement: 手順 4、 3の画像 2 Boosted Board 1st Generation Belts Replacement: 手順 4、 3の画像 3
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Belts Replacement, Belts: 手順 5、 3の画像 1 Boosted Board 1st Generation Belts Replacement, Belts: 手順 5、 3の画像 2 Boosted Board 1st Generation Belts Replacement, Belts: 手順 5、 3の画像 3
    • Compress the motor mount back .
    • Slide the belt off the axle
  6. Boosted Board 1st Generation Belts Replacement: 手順 6、 1の画像 1
    • Remove the two hex screws.
    • Remove the front hex screw.
    • When removing the Front hex screw, hold the motor mount and the truck together.
    • The springs inside the motor mount will push the motor out of the casing if they are not held together.
  7. Boosted Board 1st Generation Belts Replacement: 手順 7、 3の画像 1 Boosted Board 1st Generation Belts Replacement: 手順 7、 3の画像 2 Boosted Board 1st Generation Belts Replacement: 手順 7、 3の画像 3
    • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
    • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
終わりに
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Emily Imfeld
メンバー登録日: 10/06/16
532 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S15G7
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 1,766
