はじめに
If your phone is not responding when you are pressing the power button, you may need a power button replacement. This guide has been made to help you install your power button on your own. It will show you how to remove the screws, removing the back panel, and detach the power button.
  1. Before beginning this guide, make sure this is the guide you have selected.
    • Before beginning this guide, make sure this is the guide you have selected.
    • After assuring the guide, locate the power button show in Figure 1.
  2. Begin by locating the torx screws and remove them show in (Figure 1).
    • Begin by locating the torx screws and remove them show in (Figure 1).
    • After removing the screws, begin by use the suction tool and pry tool, to slowly remove the black plate.
    • Be Cautious do not damage phone display and or inside components while using pry tool and suction tool.
    • Once the back panel is removed, locate the power button, remove it, and replace it with the new power button show in figure 1.
    • After you successfully replace the power button, repeat the steps in reverse order to reassemble the phone.
まとめ
Alan Rodriguez
メンバー登録日: 2018年09月10日
279 ポイント
2のガイドは作成済み
チーム
Gateway, Team S1-G3, Luster Fall 2018 Gateway, Team S1-G3, Luster Fall 2018人のメンバー
GCC-LUSTER-F18S1G3
4 メンバー
4のガイドは作成済み
コメント1件
Don’t forget to remove the SIM card
Jonathan - 返信
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 28
今までの合計 39
