はじめに
Use this guide to remove the battery from your Blu Studio Selfie. Before starting this guide, check to make sure you have the required tools and that your phone is powered off.
必要な工具と部品
Turn the front of the phone away from you.
Run your fingers along the sides of the phone to identify where the case can be pulled apart.
Identify the crevice at the bottom of the battery.
Gently lift the battery free of the phone.
ある他の人がこのガイドを完成しました。
